simantic 3 Posted August 31, 2022 Posted August 31, 2022 Hello to all, I have a NAS Synology DS216j with DSM 6.2.4-25556 Update 6. Emby Server told me to upgrade the system to the version 4.7.6.0. I did it, but now it's not works. It's doesn't start. How can i do? I have tried to install the package 4.6.7.0 but the DSM told me that it's not possibile to downgrade. I don't want to lose all my library and settings. Please help me! Best Regards, Simone
simantic 3 Posted August 31, 2022 Author Posted August 31, 2022 24 minutes ago, Luke said: Hi, are you able to update to dsm 7? Hi, I have read on Synology page that to upgrade from DSM 6 to 7 the NAS needs at least 1 gb of RAM. My DS216 NAS has only 512 mb of RAM
Solution simantic 3 Posted August 31, 2022 Author Solution Posted August 31, 2022 I have uninstalled the 4.7.6.0 version and installed the 4.6.7.0 version. Now it's works and i have not loose my library and settings.
Luke 42243 Posted August 31, 2022 Posted August 31, 2022 6 hours ago, simantic said: Hi, I have read on Synology page that to upgrade from DSM 6 to 7 the NAS needs at least 1 gb of RAM. My DS216 NAS has only 512 mb of RAM Does Synology not offer the DSM 7 upgrade to you?
simantic 3 Posted August 31, 2022 Author Posted August 31, 2022 3 minutes ago, Luke said: Does Synology not offer the DSM 7 upgrade to you? yes it's offert but on the Synology DSM 7 upgrade page i have read: Before Update 8. DSM 7.0.1 consumes more system resources, including memory. We suggest that you check your NAS has at least 1 GB of memory before updating. My NAS have 512 MB of memory
