junior_dad 0 Posted August 31, 2022 Posted August 31, 2022 after a while of searching for a solution, I found some posts here in the community dealing with my same problem, but from Live TV Channels. My situation is similar but I want to watch my movies and series that are in m3u8 links, but Emby only picks the first link of the playlist that appears, which in this case are in 480p quality. I saw that in version 4.7+ you put a mechanism to change the streams that Emby recognizes, but this was only implemented on Live TV right? But what about movies and series in m3u8? It is still necessary to put this option to change the quality streams when watching movies and series that are added in m3u8 link via .STRM file!
Luke 42246 Posted August 31, 2022 Posted August 31, 2022 Hi, yes this improvement that we made is currently limited to Live TV, but in time we should be able to apply it to all areas. Thanks. 1
junior_dad 0 Posted September 3, 2022 Author Posted September 3, 2022 On 8/31/2022 at 12:25 PM, Luke said: Hi, yes this improvement that we made is currently limited to Live TV, but in time we should be able to apply it to all areas. Thanks. any predictions of when this might be available?
