Happy2Play 9814 Posted October 15, 2022 Posted October 15, 2022 Yep just noticed the majority of Trailers don't have images or metadata again but do have provider links. Refreshing didn't appear to do anything on a item So I refreshed each folder. stable and beta 1
dorinandreescu 7 Posted November 10, 2022 Posted November 10, 2022 (edited) On 10/13/2022 at 9:10 PM, Luke said: Hi, it's resolved for the next release of the server. Thanks. nope, it's not solved. still in 4.7.9.0 and in the last beta to. trailers cover/posters is broke Edited November 10, 2022 by dorinandreescu
Junglejim 385 Posted November 11, 2022 Posted November 11, 2022 23 hours ago, dorinandreescu said: nope, it's not solved. still in 4.7.9.0 and in the last beta to. trailers cover/posters is broke Seems fine to me (4.7.9.0) the channel just refreshed and I have all posters (202 items).
Cheesegeezer 3106 Posted November 11, 2022 Posted November 11, 2022 Not for me. Main Server 4.7.9 and also on my dev server 4.0.8.16 Main Dev server
Happy2Play 9814 Posted November 11, 2022 Posted November 11, 2022 @JunglejimYou possibly already refreshed them as mine are still populated but broken on test servers.
Junglejim 385 Posted November 11, 2022 Posted November 11, 2022 7 minutes ago, Cheesegeezer said: Not for me. Main Server 4.7.9 and also on my dev server 4.0.8.16 Main Dev server Did you try the refresh metadata on the folder using the 3 dot menu? sometimes that can help as @Happy2Play pointed out.
Junglejim 385 Posted November 11, 2022 Posted November 11, 2022 (edited) 39 minutes ago, Happy2Play said: @JunglejimYou possibly already refreshed them as mine are still populated but broken on test servers. I refreshed the channel and saw the new posters popping up as I scrolled through. I have had the same problem once before but the "refresh metadata on the folder" fixed that. @Cheesegeezer your trailer count for that folder looks lower that mine, I've got 202 trailers. Not sure whats going on there. I do have a scheduled task to "Refresh Internet Channels" once a week. If a refresh of the channel wont work for you try the refresh metadata on the main folder. Edited November 11, 2022 by Junglejim
Cheesegeezer 3106 Posted November 11, 2022 Posted November 11, 2022 57 minutes ago, Junglejim said: Did you try the refresh metadata on the folder using the 3 dot menu? sometimes that can help as @Happy2Play pointed out. I haven't tried that because i don't have trailers showing on Home. But i'll do it now.
Cheesegeezer 3106 Posted November 11, 2022 Posted November 11, 2022 @Junglejim Looks like the full metadata refresh with images enabled is doing the trick. There clearly is a fundimental bug then when getting the metadata and because it's not classed as a "Library" you can't set a task to refresh every 30days etc. I have my refresh Channels set to once a day anyway and that hasn't fixed it over time. I'm not desperately bothered, because i only use the trailers for Vantage Point. so i'm never bothered about the artwork. Thanks for your help buddy, much appreciated
Junglejim 385 Posted November 11, 2022 Posted November 11, 2022 (edited) 7 minutes ago, Cheesegeezer said: I haven't tried that because i don't have trailers showing on Home. But i'll do it now. That's why your trailer count is lower, your viewing trailers from the movie lib... just clicked the main folder has more. All good glad you got it sorted. Edited November 11, 2022 by Junglejim 1
Happy2Play 9814 Posted November 11, 2022 Posted November 11, 2022 @Junglejim The number count is a cache thing as I have 196 and 202 on different servers until I delete the e2ab45883bcfbae02934100719d983a7 file in the httpclient folder and run the channels task and now both are the same.
Junglejim 385 Posted November 11, 2022 Posted November 11, 2022 (edited) 15 minutes ago, Happy2Play said: @Junglejim The number count is a cache thing as I have 196 and 202 on different servers until I delete the e2ab45883bcfbae02934100719d983a7 file in the httpclient folder and run the channels task and now both are the same. I can't seem to get that to work, I still have 152 in the movie lib and 202 in the trailers folder.. I ssh into my server deleted e2ab45883bcfbae02934100719d983a7 and restarted emby and refreshed channels? Not that it bother me that much. Edited November 11, 2022 by Junglejim
Happy2Play 9814 Posted November 11, 2022 Posted November 11, 2022 (edited) @Junglejim They won't match as the Movie library Trailers tab has minPremieredate where the trailers library does not. See debug url in log. Edited November 11, 2022 by Happy2Play 1
Happy2Play 9814 Posted November 11, 2022 Posted November 11, 2022 Looks like Trailers Tab is limited to roughly the last 120 days. &MinPremiereDate=2022-07-14T11:44:13.110Z 1 1
Junglejim 385 Posted November 11, 2022 Posted November 11, 2022 1 minute ago, Happy2Play said: @Junglejim They won't match as the Movie library Trailers tab has minPremieredate where the trailers library does not. That's all good, thanks mate. It's all how you want to view them, I use all methods (home lib/movie lib/home widget).
Junglejim 385 Posted November 11, 2022 Posted November 11, 2022 1 minute ago, Happy2Play said: Looks like Trailers Tab is limited to roughly the last 120 days. &MinPremiereDate=2022-07-14T11:44:13.110Z Wow mate, your the emby detective! Great work.. Cheers 1
Cheesegeezer 3106 Posted November 11, 2022 Posted November 11, 2022 6 minutes ago, Junglejim said: Wow mate, your the emby detective! Great work.. Cheers That why he has a special emby badge!!! haha
