cnszlj 2 Posted August 30, 2022 Posted August 30, 2022 TerraMaster 64-bit (TOS 5) 下载地址错误,请EMBY修正 https://emby.media/terramaster-server.html 下载页里的下载错误地址如下: https://emby.media/emby_TOS5_APP_{version}_x86_64.tpk
Happy2Play 9811 Posted August 30, 2022 Posted August 30, 2022 Doesn't look like that version was ever built. But the devs will look into it.
Luke 42237 Posted August 30, 2022 Posted August 30, 2022 @cnszlj Hi, yes these TOS 5 packages are brand new. Can you try installing the beta and let us know how that goes? Thanks !
Happy2Play 9811 Posted August 30, 2022 Posted August 30, 2022 @Luke Web page may need a note to try beta until release is available.
cnszlj 2 Posted August 30, 2022 Author Posted August 30, 2022 (edited) 17 minutes ago, Luke said: @Happy2Play Emby Server (BETA) for TerraMaster Manual Installation 64-bit (TOS 5) 已安装,不能正常使用,不能扫描媒体库 Edited August 30, 2022 by cnszlj
Luke 42237 Posted August 30, 2022 Posted August 30, 2022 1 minute ago, cnszlj said: Emby Server (BETA) for TerraMaster Manual Installation 64-bit (TOS 5) 已安装,不能正常使用,不能扫描媒体库 What does that mean exactly? What happens when you try? Can you please attach the emby server log? thanks.
cnszlj 2 Posted August 30, 2022 Author Posted August 30, 2022 (edited) @Luke embyserver.txt Edited August 30, 2022 by cnszlj
Happy2Play 9811 Posted August 30, 2022 Posted August 30, 2022 @cnszlj there is a permission issue on your custom paths and Volume2. 2022-08-30 08:29:16.827 Info Main: Cache path: /Volume2/Eden Library/ANNEX/cache 2022-08-30 08:29:16.827 Info Main: Internal metadata path: /Volume2/Eden Library/ANNEX/metadata/ metadata examples System.UnauthorizedAccessException: Access to the path '/Volume2/伊甸园影音库/ANNEX/metadata/metadata/SubtitleFonts' is denied. System.UnauthorizedAccessException: Access to the path '/Volume2/伊甸园影音库/ANNEX/transcoding-temp' is denied. System.UnauthorizedAccessException: Access to the path '/Volume2/伊甸园影音库/Music(MV)/MKV/汪明荃 - 万水千山总是情 - 2016北京卫视春晚现场-poster.jpg' is denied.
Luke 42237 Posted August 30, 2022 Posted August 30, 2022 It looks like you customized the server cache and metadata paths but did not ensure that the server has write access. Can you try blanking those out and setting them back to default?
