AlekT481 1 Posted August 29, 2022 Posted August 29, 2022 The episodes from 101 and above are displayed in the wrong season with wrong names and wrong episode number. I have tried so many things and still no results. SO, does anybody know an app that lets you mass download/ edit/ grab metadata for a series or another way to fix this issue? HELPPP PLZZZZ!!!!!!
Abobader 3485 Posted August 29, 2022 Posted August 29, 2022 Hello AlekT481, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pwhodges 2025 Posted August 29, 2022 Posted August 29, 2022 Emby should handle this. Can you show us examples of your folder and file names? Paul
AlekT481 1 Posted August 29, 2022 Author Posted August 29, 2022 Nevermind the missing images it is my doing
Happy2Play 9800 Posted August 29, 2022 Posted August 29, 2022 Will look more at this later but did you change Display order on the Series to Absolute?
Solution Happy2Play 9800 Posted August 29, 2022 Solution Posted August 29, 2022 13 minutes ago, AlekT481 said: Where do I find this option? Edit metadata on Series and you should see Display order. After the chance you will need to Refresh Metadata.
Luke 42186 Posted August 29, 2022 Posted August 29, 2022 5 hours ago, Happy2Play said: Edit metadata on Series and you should see Display order. After the chance you will need to Refresh Metadata. Actually after you change this option in the metadata editor, the server will automatically kick off the metadata refresh, so no need to do that.
