Waldoo 14 Posted August 28, 2022 Posted August 28, 2022 just stopped working. it does not show any images from fan art embyserver.txt
Happy2Play 9800 Posted August 28, 2022 Posted August 28, 2022 Isn't this a network/dns issue? System.Net.Http.HttpRequestException: The requested address is not valid in its context. (webservice.fanart.tv:443) Appears to be working here.
Waldoo 14 Posted August 28, 2022 Author Posted August 28, 2022 seems a bug in your program https://stackoverflow.com/questions/50461930/the-requested-address-is-not-valid-in-its-context-when-listen-data-from-other-ma
Luke 42186 Posted August 28, 2022 Posted August 28, 2022 No that looks like you were unable to reach fanart.tv at the time. Are you still having the issue now?
Waldoo 14 Posted August 28, 2022 Author Posted August 28, 2022 I turn off the vpn and it still persist
Waldoo 14 Posted August 29, 2022 Author Posted August 29, 2022 @Luke what are all the ports emby uses ?
Waldoo 14 Posted August 30, 2022 Author Posted August 30, 2022 I restarted my computer, restarted the server, turned on the vpn I don’t know what else to do to fix this? @Luke
Waldoo 14 Posted August 30, 2022 Author Posted August 30, 2022 Microsoft Telnet> o webservice.fanart.tv 443 Connecting To webservice.fanart.tv...Could not open connection to the host, on port 443: Connect failed Microsoft Telnet> any ideas ?
pwhodges 2025 Posted August 30, 2022 Posted August 30, 2022 Something up in your firewall, it would seem to me. ISPs don't interfere with that sort of outgoing connection. Paul
Waldoo 14 Posted August 30, 2022 Author Posted August 30, 2022 @pwhodges turn off my firewall and it still persist
pwhodges 2025 Posted August 30, 2022 Posted August 30, 2022 Then you need to keep looking outwards. Is there a firewall in your router? Paul
Waldoo 14 Posted August 30, 2022 Author Posted August 30, 2022 yea comast security ill try turning it off
Waldoo 14 Posted August 30, 2022 Author Posted August 30, 2022 (edited) 47 minutes ago, pwhodges said: Then you need to keep looking outwards. Is there a firewall in your router? Paul im telling you its something to do with emby because fanart it works with plex and jellyfin and I think something is wrong with thetvdb. I turn off my router firewall and did nothing @pwhodges @Luke Edited August 30, 2022 by Waldoo
Happy2Play 9800 Posted August 31, 2022 Posted August 31, 2022 @Luke what is this request? The requested address is not valid in its context. (10.0.0.173:1790) Could it be something with the "Mullvad Tunnel"? But to me suggest a network work issue that is affecting FanArt requests also. The requested address is not valid in its context. (webservice.fanart.tv:443) But FanArt is working here on multiple Windows 10/11 systems.
Solution Luke 42186 Posted August 31, 2022 Solution Posted August 31, 2022 1 hour ago, Happy2Play said: @Luke what is this request? The requested address is not valid in its context. (10.0.0.173:1790) Could it be something with the "Mullvad Tunnel"? But to me suggest a network work issue that is affecting FanArt requests also. The requested address is not valid in its context. (webservice.fanart.tv:443) But FanArt is working here on multiple Windows 10/11 systems. Could be related to the tunnel, yes.
pwhodges 2025 Posted August 31, 2022 Posted August 31, 2022 8 hours ago, Waldoo said: im telling you its something to do with emby And how do you suppose Emby would make a telnet connection fail? Paul
Waldoo 14 Posted August 31, 2022 Author Posted August 31, 2022 It was the tunnel, I have three Emby exes spilt from the tunnel that persisted even with the vpn off. Going to submit a bug report to Mullvad. Thanks for your help
