Rolivaras 2 Posted August 28, 2022 Posted August 28, 2022 (edited) Lately I've been facing some problems with Emby in several apps, especially in the LG TV app. But now I had problems in the Web App too. Minions 2 movie color is totally weird. The android app is working normally. embyserver.txt ffmpeg-transcode-4ddda2e7-c57a-4b07-b2a6-45f37a3b58e8_1.txt Edited August 28, 2022 by Rolivaras
Happy2Play 9811 Posted August 28, 2022 Posted August 28, 2022 Not too familiar with HDR-U content. You say Andriod app worked, what was the playback method? I can only guess Direct Play. What does the program MediaInfo show for this media? Do you have Emby Premiere? As plugin and HWA warning in log. But as this is HDR and transcoding required you would need Tone Mapping to get proper colors also. TranscodeReasons=VideoCodecNotSupported,AudioCodecNotSupported Warning: Hardware acceleration is not available as it requires a valid Premiere Subscription Info Tone Mapping would be desired, but software tone mapping is disabled
Rolivaras 2 Posted August 28, 2022 Author Posted August 28, 2022 (edited) The Media Info: Quote Unique ID : 237396941324265118347898218480244093361 (0xB298FCE079E4CA1E77E2E611F0EFF1B1) Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual.mkv Format : Matroska Format version : Version 4 File size : 19.0 GiB Duration : 1 h 27 min Overall bit rate : 30.9 Mb/s Movie name : BaixarBluray.net - Alta Definição é Aqui! Encoded date : UTC 2022-08-12 11:11:51 Writing application : mkvmerge v69.0.0 ('Day And Age') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Encoding Gui : Hybrid 2021.09.23.1 Quote General Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual-320-10.bif File size : 6.86 MiB General Unique ID : 237396941324265118347898218480244093361 (0xB298FCE079E4CA1E77E2E611F0EFF1B1) Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual.mkv Format : Matroska Format version : Version 4 File size : 19.0 GiB Duration : 1 h 27 min Overall bit rate : 30.9 Mb/s Movie name : BaixarBluray.net - Alta Definição é Aqui! Encoded date : UTC 2022-08-12 11:11:51 Writing application : mkvmerge v69.0.0 ('Day And Age') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Encoding Gui : Hybrid 2021.09.23.1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 27 min Bit rate : 29.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.150 Stream size : 18.2 GiB (96%) Title : BaixarBluray.net - Alta Definição é Aqui! Language : English Default : Yes Forced : Yes Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0500 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 400 cd/m2 Audio #1 ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 1 h 27 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 402 MiB (2%) Language : Portuguese Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 1 h 27 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 402 MiB (2%) Language : English Service kind : Complete Main Default : No Forced : No Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 19 min Bit rate : 35 b/s Frame rate : 0.144 FPS Count of elements : 690 Stream size : 20.8 KiB (0%) Language : Portuguese Default : No Forced : No Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 26 min Bit rate : 44 b/s Frame rate : 0.248 FPS Count of elements : 1291 Stream size : 28.5 KiB (0%) Language : English Default : No Forced : No Text #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 27 min Bit rate : 70 b/s Frame rate : 0.361 FPS Count of elements : 1892 Stream size : 45.2 KiB (0%) Title : SDH Language : English Default : No Forced : No Text #4 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 26 min Bit rate : 37 b/s Frame rate : 0.180 FPS Count of elements : 930 Stream size : 24.0 KiB (0%) Language : French Default : No Forced : No Menu 00:00:00.000 : en:Studio Logo 00:00:40.000 : en:Scene 2 00:06:25.000 : en:Opening Credits 00:07:34.000 : en:Scene 4 00:15:09.000 : en:Scene 5 00:22:49.000 : en:Scene 6 00:30:17.000 : en:Scene 7 00:38:17.000 : en:Scene 8 00:46:08.000 : en:Scene 9 00:52:54.000 : en:Scene 10 01:00:01.000 : en:Scene 11 01:07:41.000 : en:Scene 12 01:14:31.000 : en:Scene 13 01:19:20.000 : en:End Credits General Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual.nfo File size : 16.0 KiB General Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\clearlogo.png Format : PNG Format/Info : Portable Network Graphic File size : 141 KiB Image Format : PNG Format/Info : Portable Network Graphic Compression : Deflate Width : 3 900 pixels Height : 912 pixels Color space : RGBA Bit depth : 8 bits Compression mode : Lossless Stream size : 141 KiB (100%) General Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\fanart.jpg Format : JPEG File size : 563 KiB Image Format : JPEG Width : 2 453 pixels Height : 1 380 pixels Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Stream size : 563 KiB (100%) General Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\landscape.jpg Format : JPEG File size : 287 KiB Image Format : JPEG Width : 1 000 pixels Height : 562 pixels Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Stream size : 287 KiB (100%) ColorSpace_ICC : RGB General Complete name : Z:\EMBY SERVER OFICIAL\FILMES\Minions.The.Rise.of.Gru.2022.WEB-DL.2160p.HDR-U.V2.EAC3.5.1.Dual\poster.jpg Format : JPEG File size : 214 KiB Image Format : JPEG Width : 947 pixels Height : 1 421 pixels Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Compression mode : Lossy Stream size : 214 KiB (100%) About Android app playback, it appears as direct playback. I don't have a premiere subscription. Strange that when I added this movie, it played normally in both LG app and Web App. But now both are having trouble. Edited August 28, 2022 by Rolivaras
Luke 42241 Posted August 29, 2022 Posted August 29, 2022 Hi, tone mapping is required in order to ensure that HDR content looks correct when transcoding, and this requires Emby Premiere. Does this answer your question?
Rolivaras 2 Posted August 29, 2022 Author Posted August 29, 2022 And did this feature become premiere recently? So until these days it was working fine.
Luke 42241 Posted August 31, 2022 Posted August 31, 2022 On 8/29/2022 at 11:32 AM, Rolivaras said: And did this feature become premiere recently? So until these days it was working fine. Hi, tone mapping with transcoding has always required Premiere. But when your client device supports HDR directly, this does not require Premiere. Does that answer your question?
