croaton 9 Posted August 28, 2022 Posted August 28, 2022 On Tizen 2018 i have a very weird Play on some Movies Panel and Logs always shows direct Play but Picture is Stuttering like as they is encoding, but it's Direct Play On Plex it run's fine, but on the Fly remux to mp4 (maybe this info helps) Samsung Smart TV (UE75MU7009) Log & Mediainfo attached Regards embyserver.txt
SamES 1084 Posted August 28, 2022 Posted August 28, 2022 How many subtitle tracks, and how many audio tracks does this file have?
croaton 9 Posted August 28, 2022 Author Posted August 28, 2022 2 Audio Tracks and 32 subtracks, but this cant be the issue i have another video file also same specs and it plays fine 1
SamES 1084 Posted August 28, 2022 Posted August 28, 2022 1 minute ago, croaton said: 2 Audio Tracks and 32 subtracks, but this cant be the issue i have another video file also same specs and it plays fine That will be the problem. The internal player has issues with too many tracks. More than about 25 will usually cause issues. The recommendation is to remove some of the internal tracks. If it's an MKV file, try MkvToolnix and only select the audio and subtitle tracks that you require.
croaton 9 Posted August 28, 2022 Author Posted August 28, 2022 Ok, but Subtitles are disabled by default to play, but give it a shot 1
FrostByte 5453 Posted August 28, 2022 Posted August 28, 2022 1 hour ago, croaton said: Ok, but Subtitles are disabled by default to play, but give it a shot It doesn't really matter because you can only play one too. It's how many tracks are in the file which the Tizen player can't seem to handle. I'm guessing Plex is remuxing and removing all but maybe one to get around this. Let us know what you find, but I get this too and I've gotten to the point where I just remove all the unwanted subtitles on everything.
dennis7480 3 Posted August 28, 2022 Posted August 28, 2022 I would recommend learning how to use mkvtoolnix. Google "mkvtoolnix" "Handbrake" is another tool that can help you but mkvtoolnix is easier and more straightforward. It will allow you to delete the extra stuff in the file container. Extremely useful! You can free up HUUUUUUUGE amounts of space deleting foreign language or extra/unnecessary tracks. Will fix your specific issue because it will lower the track limit to just -1Video -1Audio -1Subtitle 1
croaton 9 Posted August 28, 2022 Author Posted August 28, 2022 (edited) 6 hours ago, FrostByte said: It doesn't really matter because you can only play one too. It's how many tracks are in the file which the Tizen player can't seem to handle. I'm guessing Plex is remuxing and removing all but maybe one to get around this. Let us know what you find, but I get this too and I've gotten to the point where I just remove all the unwanted subtitles on everything. We are checking on this, with default forced subtitle set on (including the tons of subtitles), it plays normal, very weird, elaborate more in this Week. 2 hours ago, dennis7480 said: I would recommend learning how to use mkvtoolnix. Google "mkvtoolnix" "Handbrake" is another tool that can help you but mkvtoolnix is easier and more straightforward. It will allow you to delete the extra stuff in the file container. Extremely useful! You can free up HUUUUUUUGE amounts of space deleting foreign language or extra/unnecessary tracks. Will fix your specific issue because it will lower the track limit to just -1Video -1Audio -1Subtitle Nice but i know mkvtoolnix and use it under unix including mediainfo ffmpeg etc., and handbrake is shit as Hell even as muxxer oneclick encoder whatever. But thx for the Advice. Edited August 28, 2022 by croaton 1
SamES 1084 Posted August 28, 2022 Posted August 28, 2022 The only issue with Handbrake is that it will convert the video track, which you probaly don't want. There is no way with Handbrake to just copy the video track. MkvToolnix will just copy the tracks to a new container, so it is as quick as you can write to disk, and no loss of quality, DV, etc
croaton 9 Posted August 28, 2022 Author Posted August 28, 2022 3 minutes ago, SamES said: The only issue with Handbrake is that it will convert the video track, which you probaly don't want. There is no way with Handbrake to just copy the video track. MkvToolnix will just copy the tracks to a new container, so it is as quick as you can write to disk, and no loss of quality, DV, etc it's even easier via cli on ffmpeg per mapping what you want to keep, mkvtoolnix is more for not so much nerds ;D
