Naichbindas 1 Posted August 27, 2022 Posted August 27, 2022 Hallo Eine Frage wird die Emby App für Samsung TV noch weiterentwickelt? Welche Version ist denn die letzte bis jetzt die 1.3.3, glaube ich. Wenn die auf dem TV installiert ist und es kommt vlt mal ein Update afür aktuallisert die sich dann automatisch ode muss ich mir immer die neuste Version mit USB installieren? Vielen dank. mfg
FrostByte 5453 Posted August 27, 2022 Posted August 27, 2022 There is at least one update every month. The latest version is always the one in the usb link. Version 1.3.3 was released 23 days ago, so a new version should be coming soon. The only way to automate the update process some would be to change your app region to one of the regions where the app is available in the Samsung app store. 1
Naichbindas 1 Posted August 27, 2022 Author Posted August 27, 2022 @FrostBytedanke für die Info, was muss ich da genau machen um as um zu stellen. Dann gehen auch meine anderen Apps dann auch nicht mehr die schon installiert sind, oder? Netflix und so weiter. Kann ich das danach dann wieder auf deutsch umstellen oder ist Emby dann weg. Danke. mfg
FrostByte 5453 Posted August 27, 2022 Posted August 27, 2022 You can only have apps from one region at a time. If you do change your app region, then the process will delete all apps and all settings you currently have. If you currently use another app which is only available in your region, then this might not be something you would want to do. Netflix is available in all regions. However, if Netflix is Geo locked then it may not work if your IP is from another location. However, I don't know if Netflix is geo-locked. It may not be. Yes, you can change your app region as many times as you wish. You will just have to redo all your settings each time you change it. I've changed mine to four different regions and back one day with no problem.
Naichbindas 1 Posted August 29, 2022 Author Posted August 29, 2022 @FrostByteDanke für die Hilfe. ich habe es per USB installiert und hoffe das wenn ein Update kommt das dann auch die App mit aktuallisiert wird. Das mit dem hin und her auf em TV ist mir doch zu aufwändig. mfg 1
lejared 29 Posted August 29, 2022 Posted August 29, 2022 Du musst das Update jedes Mal wieder manuell per USB installieren. Je nach TV-Modell musst du zuvor sogar die alte Emby-App erst deinstallieren, bevor du die aktuelle Version dann neu installieren kannst. Leider gibt es derzeit keine komfortablere Möglichkeit die Emby-App auf einem Samsung TV außerhalb der USA zu nutzen.
serpi 82 Posted August 29, 2022 Posted August 29, 2022 3 minutes ago, lejared said: Leider gibt es derzeit keine komfortablere Möglichkeit die Emby-App auf einem Samsung TV außerhalb der USA zu nutzen. Doch, du kannst nach GB ziehen, da gibt es die App angeblich auch im Store Ciao, Alfred 1
FrostByte 5453 Posted August 29, 2022 Posted August 29, 2022 21 minutes ago, serpi said: Doch, du kannst nach GB ziehen, da gibt es die App angeblich auch im Store Ciao, Alfred It would probably be easier to just change the app region on your TV 1
