Newling 1 Posted August 26, 2022 Posted August 26, 2022 Hi folks, while checking all menu options (during tracing the log), i found the following: **snip** 2022-08-26 22:25:52.271 Error Server: Error processing request *** Error Report *** Version: 4.7.6.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.19.0-21-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.249-2 (2022-06-30) Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/opt/emby-server/system/dashboard-ui/modules/loading/loader2.gif'. File name: '/opt/emby-server/system/dashboard-ui/modules/loading/loader2.gif' **snip** I could repeat the error with the clicks: "Diagnostic Options" - "FFmpeg Options". It is a very minor bug, the menu (of FFmpg options) seems to display correct. Best Andi
softworkz 5133 Posted August 27, 2022 Posted August 27, 2022 4 hours ago, Luke said: @softworkz @Luke - you have removed it - now it's broken loader2 is still needed in some cases, because the CSS animated loader restarts on each dynamic UI update while gif animations keep running continuously in those cases. see emby-web-mobile/issues/141
