KeyserSooze 1 Posted August 26, 2022 Posted August 26, 2022 Hi, i've add a container in docker (RPI4 on OMV5). Deployment successfully but i've theese errors: s6-svscan: warning: unable to iopause: Operation not permitted s6-svscan: warning: executing into .s6-svscan/crash s6-svscan crashed. Killing everything and exiting. s6-linux-init-hpr: fatal: unable to reboot(): Operation not permitted s6-svscan: warning: unable to iopause: Operation not permitted s6-svscan: warning: executing into .s6-svscan/crash Any idea? thx
RobbyLeeTinte 0 Posted August 27, 2022 Posted August 27, 2022 Same thing here. Following as I have no idea either.
Luke 42238 Posted August 28, 2022 Posted August 28, 2022 Hi there, please attach the emby server log from when this happened: Thanks.
KeyserSooze 1 Posted August 30, 2022 Author Posted August 30, 2022 My log file attached. _emby_logs.txt
Luke 42238 Posted August 30, 2022 Posted August 30, 2022 12 hours ago, KeyserSooze said: My log file attached. _emby_logs.txt 3.85 kB · 1 download @KeyserSooze this looks like a system log. Can you please attach the emby server log file? Thanks.
KeyserSooze 1 Posted September 3, 2022 Author Posted September 3, 2022 This is the only log i have. Emby server seems not started
Solution KeyserSooze 1 Posted September 4, 2022 Author Solution Posted September 4, 2022 Solved! Wrong version of emby. I've correct it to arm v7 version for my rpi4 and work. Topic closed? 1
