Solution GrimReaper 4847 Posted May 4, 2023 Solution Posted May 4, 2023 As said: 1 hour ago, GrimReaper said: DV file, likely Profile 5 so no fallback HDR layer 2 minutes ago, BladeRunner said: HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Your TV doesn't support DV and there's no HDR10(+) layer to fall back to, as P5.
BladeRunner 2 Posted May 4, 2023 Author Posted May 4, 2023 2 minutes ago, GrimReaper said: As said: Your TV doesn't support DV and there's no HDR10(+) layer to fall back to, as P5. That would make sense. Is it possible to convert these sorts of files?
rbjtech 5335 Posted May 4, 2023 Posted May 4, 2023 10 minutes ago, BladeRunner said: That would make sense. Is it possible to convert these sorts of files? Yes - but it's involved. My honest advice is to just use a suitable source file for the hardware you have - ie SDR, HDR10 or HDR10 Plus 1
BladeRunner 2 Posted May 4, 2023 Author Posted May 4, 2023 1 minute ago, rbjtech said: Yes - but it's involved. My honest advice is to just use a suitable source file for the hardware you have - ie SDR, HDR10 or HDR10 Plus Thanks guys. At least I've got an answer. I'll keep it in mind for the future. 2
