MarcusJ 18 Posted August 24, 2022 Posted August 24, 2022 I am trying to use the Emby Live TV "Channels" screen to dramatically reduce the number of channels shown when I watch Live TV thru Emby.The sheer number of channels makes it completely unwieldly. I have over 300,000 IPTV channels and VOD streams, and would like to chop that down to about 500. I am familiar with xTeVe as an option, but I am trying to avoid using that if possible. Unless I am missing something (likely), I would currently need to go through and de-select each one of the 300,000+ channels to remove them from being shown to users on Live TV. Is that correct? Obviously, it would be soooooo much easier to have a "Master" select button at the top to select or de-select ALL channels. THat way, I could de-select all 300,000+ channels and then I would only need to go through and select the 4-500 I want. The effort goes from hundreds of hours of silly, repetitive work down to about 30 minutes of thoughtful work. Alternatively, there could be a configuration item in which the emby admin can choose to show all channels on the "Channels" screen as "Selected" or "De-Selected" by default. Each admin could choose which option works best for them based on their channel list size. If I'm missing something, please help me understand it. Otherwise, if there are other ideas for more efficiently managing these channels with current functionality, I would love to hear them. Thanks!
mike3821 67 Posted August 25, 2022 Posted August 25, 2022 I use xtreme editor. A online paid service to build out what channels I want. I then use Emby to pull in the channels and then associate EPG data using Emby. Then manual map the channels.
RobDenny 9 Posted August 25, 2022 Posted August 25, 2022 You could install Steve it's free and can handle 300k channels easily, filter them down by group to what you want.
mike3821 67 Posted August 25, 2022 Posted August 25, 2022 12 hours ago, RobDenny said: You could install Steve it's free and can handle 300k channels easily, filter them down by group to what you want. Are you referring to xteve?
mike3821 67 Posted August 26, 2022 Posted August 26, 2022 5 hours ago, RobDenny said: Yes Thanks I just set this up using dummy channels and 120 minute… still don’t know what 120 minute means?
RobDenny 9 Posted August 26, 2022 Posted August 26, 2022 To have an active channel in xteve it required some channel/EPG data, the 120 mins dummy data is just there for convenience, it allows you to enable the channel without having the EPG data. The way you have done it is spot on, as you can then use the EPG supplied data inside emby itself to replace the dummy 120 mins data. 1
EODCrafter 181 Posted August 26, 2022 Posted August 26, 2022 If you can find it, IPTV Boss is pretty good too.
mike3821 67 Posted August 26, 2022 Posted August 26, 2022 5 hours ago, RobDenny said: To have an active channel in xteve it required some channel/EPG data, the 120 mins dummy data is just there for convenience, it allows you to enable the channel without having the EPG data. The way you have done it is spot on, as you can then use the EPG supplied data inside emby itself to replace the dummy 120 mins data. Thanks. I've moved everything over to xteve and now can save a few dollars a year. Thanks again!
darrenkdean 31 Posted August 29, 2022 Posted August 29, 2022 We use iptveditor.com. It's give or take $15 / year & worth its weight in gold. Channel sorting & categories, channel numbering, EPG, channel logos, & auto updating stream names like ESPN+. Makes quick work of it. 1
MarcusJ 18 Posted August 29, 2022 Author Posted August 29, 2022 15 minutes ago, darrenkdean said: We use iptveditor.com. It's give or take $15 / year & worth its weight in gold. Channel sorting & categories, channel numbering, EPG, channel logos, & auto updating stream names like ESPN+. Makes quick work of it. Thank you, Darren! I'll check it out.
Solution mike3821 67 Posted August 29, 2022 Solution Posted August 29, 2022 20 hours ago, darrenkdean said: We use iptveditor.com. It's give or take $15 / year & worth its weight in gold. Channel sorting & categories, channel numbering, EPG, channel logos, & auto updating stream names like ESPN+. Makes quick work of it. After to many issues with xteve I just paid these guys. So far it’s excellent. EPG isn’t much value under Emby. Emby provides a more granular list of movies and tv shows under live tv/programs. what I like over xtreme editor is the fact I can sort, and number channels. No more need to do this under Emby. Only EPG stuff.
MarcusJ 18 Posted August 29, 2022 Author Posted August 29, 2022 Sounds great, but unfortunately, they limit the number of streams to 120,000. My M3U has 300,000.
mike3821 67 Posted August 29, 2022 Posted August 29, 2022 Just now, MarcusJ said: Sounds great, but unfortunately, they limit the number of streams to 120,000. My M3U has 300,000. What on earth do you need 300,000 channels for?
MarcusJ 18 Posted August 29, 2022 Author Posted August 29, 2022 I don't! I ordered U.S., Canada, and U.K. channels only, and they sent this m3u. I was expecting 15-20,000, but got 300,000+. For some strange reason, they included hundreds of thousands of VOD streams in the m3u. They're mostly TV shows with each episode taking up a channel/stream. Getting rid of them is the primary reason I need an m3u editor.
BillOatman 597 Posted August 30, 2022 Posted August 30, 2022 On 8/26/2022 at 5:46 AM, EODCrafter said: If you can find it, IPTV Boss is pretty good too.
darrenkdean 31 Posted August 30, 2022 Posted August 30, 2022 I believe most iptv providers will allow you to limit the categories of channels they supply from the iptv provider account dashboard. No need to have channels supplied in the m3u, you're never going to use.
MarcusJ 18 Posted August 30, 2022 Author Posted August 30, 2022 4 hours ago, darrenkdean said: I believe most iptv providers will allow you to limit the categories of channels they supply from the iptv provider account dashboard. No need to have channels supplied in the m3u, you're never going to use. I went back to my IPTV provider and had them remove most of those void streams. The m3u now has around 50,000 channels - still way too many, but now under the iptveditor limit. Darren, how good is the iptveditor.com EPG? Is it extensive? Accurate? How many days of EPG data can you get?
RobDenny 9 Posted August 30, 2022 Posted August 30, 2022 Is the emby EPG that bad? I find it really good! Has all the episode data and everything.
MarcusJ 18 Posted August 30, 2022 Author Posted August 30, 2022 34 minutes ago, RobDenny said: Is the emby EPG that bad? I find it really good! Has all the episode data and everything. The emby EPG data is good, but it is limited to one day or less of data. I have the emby configuration set to 14 days of EPG data, but I never get more than a day's worth of data on a subset of channels. I'm really looking for a good, complete, accurate, frequently updated EPG solution that is as close to my old cable TV guide as possible. If I have to pay for that, I would do it if the quality of the solution is where it needs to be to truly replace cable TV.
Luke 42241 Posted August 30, 2022 Posted August 30, 2022 59 minutes ago, RobDenny said: Is the emby EPG that bad? I find it really good! Has all the episode data an 19 minutes ago, MarcusJ said: The emby EPG data is good, but it is limited to one day or less of data. I have the emby configuration set to 14 days of EPG data, but I never get more than a day's worth of data on a subset of channels. I'm really looking for a good, complete, accurate, frequently updated EPG solution that is as close to my old cable TV guide as possible. If I have to pay for that, I would do it if the quality of the solution is where it needs to be to truly replace cable TV. d everything. Emby guide data supports 14 days out at least. The data is generally very good. It's just a matter of whether it's offered in your country or not. 1
MarcusJ 18 Posted August 30, 2022 Author Posted August 30, 2022 3 minutes ago, Luke said: Emby guide data supports 14 days out at least. The data is generally very good. It's just a matter of whether it's offered in your country or not. Luke, I'm in the U.S. and I have emby EPG Data set to 14 days, but I have never received more than 1 day's worth of data...ever. So when you refer to it being "offered", what does that mean? Am I being limited by my IPTV provider? Does emby limit the EPG data it provides? If emby receives its EPG data from a third party, is that third party the bottleneck. My question is not rhetorical, I really don't understand where this data comes from.
Luke 42241 Posted August 30, 2022 Posted August 30, 2022 25 minutes ago, MarcusJ said: Luke, I'm in the U.S. and I have emby EPG Data set to 14 days, but I have never received more than 1 day's worth of data...ever. So when you refer to it being "offered", what does that mean? Am I being limited by my IPTV provider? Does emby limit the EPG data it provides? If emby receives its EPG data from a third party, is that third party the bottleneck. My question is not rhetorical, I really don't understand where this data comes from. Maybe you're using xml coming from your iptv provider. That's not emby guide data. That's just your own xml data imported into emby server.
MarcusJ 18 Posted August 30, 2022 Author Posted August 30, 2022 I have emby guide data set as my primary epg data source in emby. I also added the xml link from my iptv provider. Still, I have never received more than a day's worth of data.
RobDenny 9 Posted August 30, 2022 Posted August 30, 2022 thats really weird, because I have a similar setup, US channels, but I am in the UK, and I am getting US EPG data to till Tuesday next week, so 7 days. I wouldnt use or even setup the EPG data from your provider, as in my experience its c.r.a.p I use this TV guide data setup. Here's the data next week.
