Karpana 9 Posted September 7, 2022 Posted September 7, 2022 @Happy2Play I did the update to the plugin, restarted emby and the error is still happening. I'm in the process of refreshing the metadata on all my libraries, which is understandably taking a while, and while report back once that's done and I've had a chance to rerun the stats task.
Karpana 9 Posted September 7, 2022 Posted September 7, 2022 The metadata refresh took a while but finished overnight. I tried the stats task the morning and it is still failing at the same point 88%. The debug logging shows it's dying at the same point it was before. I tried taking the file just before out of the folder (and refreshing the library) and it still fails. Which implies to me that it's the 'next file' or 'next step' that is failing out.
Karpana 9 Posted September 7, 2022 Posted September 7, 2022 I noticed that the Statistics Plugin was updated again last night, this time 3.0.3.0 and gave it an install, restarted the emby server, and ran the task. Same error message, still at 88.0% Object reference not set to an instance of an object. at Statistics.Helpers.Calculator.CalculateMovieCodecs() at Statistics.ScheduledTasks.CalculateStatsTask.MediaBrowser.Model.Tasks.IScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) I re-enabled DEBUG LOG, and ran it again, and a made a few observations Still fails at the exact same point (see below) it no longer shows the video quality (720p, 1080p, etc..) but now shows seemingly the codec? (h264, mpeg4, hevc) it seems to only get about 67 episodes in before it fails out... 2022-09-07 08:23:57.390 Debug Statistics: CalculateMovieCodecs-episode Quantum Leap: 8 1/2 Months 2022-09-07 08:23:57.391 Debug Statistics: hevc 2022-09-07 08:23:57.391 Debug Statistics: CalculateMovieCodecs-episode Young Sheldon: 8-Bit Princess and a Flat Tire Genius 2022-09-07 08:23:57.391 Debug Statistics: h264 2022-09-07 08:23:57.391 Error TaskManager: Error *** Error Report *** Version: 4.8.0.8 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.15.0-47-generic (buildd@lcy02-amd64-060) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #51-Ubuntu SMP Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Statistics.Helpers.Calculator.CalculateMovieCodecs() at Statistics.ScheduledTasks.CalculateStatsTask.MediaBrowser.Model.Tasks.IScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: statistics TargetSite: statistics.Models.Configuration.ValueGroup CalculateMovieCodecs() 2022-09-07 08:23:57.392 Debug TaskManager: Calculate statistics for all users Failed after 0 minute(s) and 48 seconds 2022-09-07 08:23:57.396 Debug NotificationManager: Sending notification via Email Notifications to user <***AdminUser***> 2022-09-07 08:23:57.396 Info App: Sending email <***AdminEmail@domain.com***> with subject Emby: Calculate statistics for all users failed 2022-09-07 08:23:59.173 Info App: Completed sending email <***AdminEmail@domain.com***> with subject Emby: Calculate statistics for all users failed
Karpana 9 Posted September 8, 2022 Posted September 8, 2022 I noticed a new version of Statistics was releases (3.0.3.1), that indicates more logging. I'm uploading an Anonymized Log that represents. (only changes to the file were to scrub the admin id and the admin email address that are in the log) Restart Emby Server Enable DEBUG LOGging running the statistics job Restarting the Emby Server embyserver-63798217786.txt
Happy2Play 9814 Posted September 8, 2022 Posted September 8, 2022 27 minutes ago, Karpana said: I noticed a new version of Statistics was releases (3.0.3.1), that indicates more logging. I'm uploading an Anonymized Log that represents. (only changes to the file were to scrub the admin id and the admin email address that are in the log) Restart Emby Server Enable DEBUG LOGging running the statistics job Restarting the Emby Server embyserver-63798217786.txt 1.1 MB · 1 download Multiple topic discussing this where yours is still failing while this user has it working.
Karpana 9 Posted September 10, 2022 Posted September 10, 2022 I'll jump over then @Happy2Play I've tried removing the media that's before/after the failure/error. I'm getting the distinct impression that the specific item that is failing isn't being correctly logged, so it feel like a needle in a haystack
Happy2Play 9814 Posted September 13, 2022 Posted September 13, 2022 As discussed in the other topic the issue is Unidentified Series in Emby and Stats now choke on them. Currently only fix is finding the offending Series/episodes, you have to copy the database and run this query to find the problem items. as couple posts above in that link shows and example.
evanover 2 Posted January 22, 2023 Posted January 22, 2023 (edited) Been receiving this error for months when running Statistics. Error stated after update to 3.0.5.1 Index was out of range. Must be non-negative and less than the size of the collection. (Parameter 'index') at System.Collections.Generic.List`1.get_Item(Int32 index) at Statistics.Helpers.Calculator.CalculateMostWatchedShows(UpdateModel tvdbData) at Statistics.ScheduledTasks.CalculateStatsTask.MediaBrowser.Model.Tasks.IScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) embyserver-63809953373.txt embyserver.txt Edited January 22, 2023 by evanover
Lacika555 0 Posted January 26, 2023 Posted January 26, 2023 (edited) On 1/22/2023 at 10:44 PM, evanover said: Been receiving this error for months when running Statistics. Error stated after update to 3.0.5.1 Index was out of range. Must be non-negative and less than the size of the collection. (Parameter 'index') at System.Collections.Generic.List`1.get_Item(Int32 index) at Statistics.Helpers.Calculator.CalculateMostWatchedShows(UpdateModel tvdbData) at Statistics.ScheduledTasks.CalculateStatsTask.MediaBrowser.Model.Tasks.IScheduledTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) embyserver-63809953373.txt 84.96 kB · 0 downloads embyserver.txt 1013.33 kB · 0 downloads same here It works with the older version, (3.0.4.0) but unfortunately the current version is returned due to the auto update. Edited January 26, 2023 by Lacika555
evanover 2 Posted January 26, 2023 Posted January 26, 2023 Yes, both versions 3.0.5.0 and 3.0.5.1 return the same error.
