dredd1963 17 Posted August 24, 2022 Posted August 24, 2022 Hi Amy using the desktop version of emby theater on windows 10. When I leave the settings menu to select the ratio change,when I came out off settings, the on-screen display does not disappear. Even after 5 mins it didn't disappear, so I to do it manually. This as been going on for a few months.
dredd1963 17 Posted August 25, 2022 Author Posted August 25, 2022 Using a remote control luke. Sorry for late reply
dredd1963 17 Posted August 25, 2022 Author Posted August 25, 2022 (edited) Not sure of the version as the TV is in use at mo, but I had to redownload after last week's win 10 update. I had download from the site. Edited August 25, 2022 by dredd1963 Tidy up text
FrostByte 5453 Posted August 25, 2022 Posted August 25, 2022 (edited) 1 hour ago, Luke said: @FrostByte are you able to reproduce? Yes, but it's everything on the cog wheel except SFN which never closes the OSD Other items elsewhere such subtitles, etc will close the OSD after a few seconds once selecting something v3.0.16 and I was using a kb. Edited August 25, 2022 by FrostByte
Luke 42239 Posted August 26, 2022 Posted August 26, 2022 Can you try restarting the app and let me know if it's still an issue? Thanks.
dredd1963 17 Posted August 26, 2022 Author Posted August 26, 2022 Hi Luke, restarted the app but the issue still remains am afraid.
FrostByte 5453 Posted August 26, 2022 Posted August 26, 2022 8 minutes ago, Luke said: @FrostByte what about you? Yes, still happens. If I use the mouse, it's fine, but using the kb the OSD never goes away automatically
FrostByte 5453 Posted August 31, 2022 Posted August 31, 2022 I can still produce it using v.16 using kb. When using the mouse, it doesn't happen.
dredd1963 17 Posted September 4, 2022 Author Posted September 4, 2022 Morning luke,. Looks like the osd is now operating normally now, I noticed that the settings button is above the progress line. Was the position of the setting button causing the problem? Thanks for your help.
Luke 42239 Posted September 4, 2022 Posted September 4, 2022 No. The change allows you to get to the subtitle button with fewer clicks now.
