mickle026 653 Posted April 16, 2025 Author Posted April 16, 2025 18 hours ago, chaosyeah said: not suport jav.... emmm... There are literally 100,000's of jav titles, and you can request them too, they might take a week or so to update the images but you can request them and they will add aand be available soon.
justinoh 0 Posted April 17, 2025 Posted April 17, 2025 On 3/15/2025 at 2:53 PM, mickle026 said: I have not been checking in on the servers scraper because I have been extremely busy elsewhere, I will check it. Is it mainstream ,jav or both? Any chance you have taken a look at this? It looks like this only affects newly added javlibrary links. I can see that the fullcover is downloaded but not the poster image. In some rare cases, if I Edit Image, then run a search manually, the poster is then found. Thank you!
mickle026 653 Posted April 17, 2025 Author Posted April 17, 2025 47 minutes ago, justinoh said: Any chance you have taken a look at this? It looks like this only affects newly added javlibrary links. I can see that the fullcover is downloaded but not the poster image. In some rare cases, if I Edit Image, then run a search manually, the poster is then found. Thank you! Yes, there is a backup process running at the moment that creates the posters from the full-covers, but that is intensive so it only runs once a week or more if I trigger it. The JAV is fetched and added to the Database, but as you noted it initially has only the full cover image (backdrop), the secondary program is creating posters, back covers, thumbnails etc from that full-cover, but like I said that's happening once or twice a week only at the moment. So the JAV is added but it can be up to a week before the Poster appears with it. It is being done, the Posters are being generated - many 1000's per week. The other caveat is JAV Library now use cloud-flare so they block the scraper or ban the scraper IP if it goes too fast. It has to be creative in fooling the site that its not a bot! Its not just JAV sites that have this issue - I know I need to fix it. I will update the scraper when I have time, so it does the posters creations from the full-cover as the full-cover is grabbed, but I don't have time at the moment. Quote if I Edit Image, then run a search manually, the poster is then found. This is because they are being added, but up to a week later than the data, maybe after you scanned your item in.
justinoh 0 Posted April 17, 2025 Posted April 17, 2025 Interesting stuff and good to know! Thanks so much for taking the time to respond.
mickle026 653 Posted April 28, 2025 Author Posted April 28, 2025 My background worker will not fetch from Javlibrary at the moment, the site appears to have been hacked again with links taking you to cams and trying to install avgsecure browser (a virus) Not sure when it will be back to normal
justinoh 0 Posted April 28, 2025 Posted April 28, 2025 Works ok for me but I am logged in to the site. Maybe the ads are for non logged in users?
mickle026 653 Posted April 29, 2025 Author Posted April 29, 2025 4 hours ago, justinoh said: Works ok for me but I am logged in to the site. Maybe the ads are for non logged in users? with ads and redirects to malicious websites?
justinoh 0 Posted April 29, 2025 Posted April 29, 2025 Whilst logged in I see ads but have not been redirected to other sites ever, if that's what you're asking?
ackitsme 0 Posted May 12, 2025 Posted May 12, 2025 Is ADM still available? All of the links to download the various versions appear to be dead.
mickle026 653 Posted May 12, 2025 Author Posted May 12, 2025 1 hour ago, ackitsme said: Is ADM still available? All of the links to download the various versions appear to be dead. 18July2024 version in post 1 works fine, but here it is as well. ADMv2(18July2024).zip
DanieleCasaSRV 4 Posted May 21, 2025 Posted May 21, 2025 hi, i can't get the plugin to work, i checked on some sites where it gets the metadata and the title exists, but it doesn't apply it to the movie. it's a scene rather than a movie, but it's there. do i have to rename the file somehow? i only put the title in this case, thanks
mickle026 653 Posted May 21, 2025 Author Posted May 21, 2025 The plugin doesn't visit any sites, it uses its own database, and it doesn't really support scenes only vod and full movies. Pm me the title and link and I'll check it. Don't post it here.
ecrispy 38 Posted June 10, 2025 Posted June 10, 2025 I just found this. Is it possible to implement a rename feature in this - I.e. once it matches the file it renames and moves it to desired directory structure? or do you have any advice for other tools/scrapers that can do this?
knotigan 0 Posted June 23, 2025 Posted June 23, 2025 2025-06-23 13:17:23.327 Error App: Error in ADMv2 *** Error Report *** Version: 4.8.11.0 Command line: /Applications/EmbyServer.app/Contents/MacOS/EmbyServer.dll -noautorunwebapp Operating system: Darwin 24.5.0 Darwin Kernel Version 24.5.0: Tue Apr 22 19:54:49 PDT 2025; root:xnu-11417.121.6~2/RELEASE_ARM64_T6000 Framework: .NET 6.0.36 OS/Process: arm64/arm64 Runtime: Applications/EmbyServer.app/Contents/MacOS/System.Private.CoreLib.dll Processor count: 10 Data path: /Users/<USER>/.config/emby-server Application path: /Applications/EmbyServer.app/Contents/MacOS System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at ADMv2.ADMMetadataProvider.GetMovieMetadataFromRemoteSearchResult(String MovieName, CancellationToken cancellationToken) at ADMv2.ADMMetadataProvider.GetMetadata(MovieInfo info, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, LibraryOptions libraryOptions, String logName, TIdType id, IRemoteMetadataProvider`2[] providers, MetadataRefreshOptions options, CancellationToken cancellationToken) Source: ADMv2 TargetSite: System.Threading.Tasks.Task`1[MediaBrowser.Controller.Providers.MetadataResult`1[MediaBrowser.Controller.Entities.Movies.Movie]] GetMovieMetadataFromRemoteSearchResult(System.String, System.Threading.CancellationToken) ^^ Movie is in JAVLibrary, renamed it to the ID for easy matching, hit refresh metadata and ended up with this crash. Not sure what else I can provide to make it easier to track down.
mickle026 653 Posted July 4, 2025 Author Posted July 4, 2025 (edited) ADM has been taken offline This is in response to new legislation https://www.ofcom.org.uk/online-safety/protecting-children/age-checks-for-online-safety--what-you-need-to-know-as-a-user I am not risking any fine let alone an 18 million fine for something I provide for free. I might put it back online once I figure out what I am going to do to comply - if I choose to do so that is........... sorry for the inconvenience, most users are probably over 18 years old but I now have to ensure everything has been done to make sure and keep records - not sure i want to do that. Edited July 4, 2025 by mickle026
justinoh 0 Posted July 7, 2025 Posted July 7, 2025 (edited) ADM was the best option by far and worked incredibly well. Shame that it has to come to this but understand its a huge risk for you. Would it be feasible though for the average home user to run ADM off a home media server perhaps? EDIT: To clarify, this would be for an individual to run all the required services on a home server to have ADM collect links, scrape, store and update Emby for personal use that is. The user would then proceed as usual to enter the links to scrape and have ADM/Emby update as usual. Edited July 7, 2025 by justinoh
Sid10 0 Posted July 7, 2025 Posted July 7, 2025 this is terrible news and no one expects you to go out your way todo anything you dont deem worthwhile would be intersted if we could run ourselves or similar if possible? and thanks as always
mickle026 653 Posted July 8, 2025 Author Posted July 8, 2025 ADM Plugin does not scrape anything, it accesses a flatfile database which is huge. I still have all the data, all I have done at the moment is turned the server off. Currently I have very little time on my hands to do much of anything computer related. However I am open to ideas, so it could possibly be re-instated in the not so distant future. All I have to do is comply legally by making absolutely sure no minors can access the data. For me that's a bit of a challenge, the current server would need some changes as well as the plugin. 2
SortSpion 1 Posted July 8, 2025 Posted July 8, 2025 You could also alter your DB slightly to ensure that the rule does not apply to your DB. As far as I understand, the rule only applies if you have ties with the UK (which I assume that you do) and fulfil one or more of Provide a user-to-user services - an online service that allow users to interact with each other (I'm marking this up as a NO) Provide a Search services - online services that include a search engine for more than one page or DB (you only have one DB so this is a NO too) publishes or displays pornographic content - It does not include text or written content. (this can be a YES if you provide or link to the images. But if you remove these then this is a NO) So in short, as long as you a) cut your ties with the UK , or b) make sure not to display pornographic clips or images, then you are in the clear and no check is needed. I'm not sure how big a part of the provided value the cover images are, but I assume that users can find these elsewhere? And as a bonus, here is the link to where I found the info: https://ofcomlive.my.salesforce-sites.com/formentry/RegulationChecker
mickle026 653 Posted July 8, 2025 Author Posted July 8, 2025 Because the movie dvd covers and the textual overviews are often pornographic then ADM is required to comply with this law. There no getting away from it
SortSpion 1 Posted July 8, 2025 Posted July 8, 2025 The covers, sure. But the textual overviews are specifically exempt from the rule. Quote The Act defines pornographic content as content that was produced solely or principally for the purpose of sexual arousal. This only includes audio, image and video content. It does not include text or written content. emphasis mine
mickle026 653 Posted July 8, 2025 Author Posted July 8, 2025 Maybe so in the description, bit it doesn't change the fact that I have to comply with this law. The easiest thing to do for me is just switch it off, it's doesn't make me anything, but does cost a little. I don't use it at all. It was made to fill a space whilst I learned plugin development and other programming techniques.
justinoh 0 Posted July 15, 2025 Posted July 15, 2025 I don't mind paying a once off fee to help cover costs, so it doesn't cost you to keep this project running and keep the plugin alive. Alternatively, if the plugin can be run directly off our local machines I'd be up for that too
