deepac7 9 Posted February 3, 2025 Posted February 3, 2025 I just managed to install this plugin along with the custom links plugin. Just curious, this is valid only for "movies", right? Individual scenes don't apply. example, Brazzers - Brazzers Extra - Sexecutioners - Angela White or Mofos - Public Pickups - Meeting Abella Danger etc
deepac7 9 Posted February 3, 2025 Posted February 3, 2025 24 minutes ago, deepac7 said: I just managed to install this plugin along with the custom links plugin. Just curious, this is valid only for "movies", right? Individual scenes don't apply. example, Brazzers - Brazzers Extra - Sexecutioners - Angela White or Mofos - Public Pickups - Meeting Abella Danger etc I mean I understand you have mentioned somewhere in the thread that if you include "scenes" it wouldn't be ADM. Asking with just a tiny bit of hope since my collection is purely based on actors and it majorly contains individual scenes.
mickle026 653 Posted February 3, 2025 Author Posted February 3, 2025 if the scenes are avaliable as vod's on adultdvdempire or Jeedoo then they might be in there, I have been including those for a while becuase they come with a dvd type box cover. I have no plans to mess up the database with millions of other clips that only have screenshots as the covers. Other people can write a plugin that does that, infact there are several on git hub already that do that.
deepac7 9 Posted February 3, 2025 Posted February 3, 2025 27 minutes ago, mickle026 said: if the scenes are avaliable as vod's on adultdvdempire or Jeedoo then they might be in there, I have been including those for a while becuase they come with a dvd type box cover. I have no plans to mess up the database with millions of other clips that only have screenshots as the covers. Other people can write a plugin that does that, infact there are several on git hub already that do that. I understand. But....All most all the new releases from adultime . com come with covers these days. While they are not particularly dvd type box cover but a legit "non screenshot" dedicated cover images. Eg. Scene: The Yes List - Alone At The Park, Studio: Adult Time Originals. And I believe these are updated on data 18 on almost realtime.
mickle026 653 Posted February 3, 2025 Author Posted February 3, 2025 (edited) can you share an example? and maybe an url where i can scrape this information? and i will look at if adding the source is feasable for my system I only see landscape type images Dont post the cover here, send it in a pm Edited February 3, 2025 by mickle026
deepac7 9 Posted February 3, 2025 Posted February 3, 2025 15 minutes ago, mickle026 said: can you share an example? and maybe an url where i can scrape this information? and i will look at if adding the source is feasable for my system I only see landscape type images Dont post the cover here, send it in a pm Oh if landscape orientation is an issue....then yeah, most of them are in landscape. But here you go, The Yes List - Alone At The Park, w/ Vince Karter | DATA18 https://www.data18.com/scenes/1357131
mickle026 653 Posted February 3, 2025 Author Posted February 3, 2025 Thanks for the link it clarifys a few things for me. I will consider this, as its do-able, but is there any other sites than data 18 where i could get this info?, data 18 is a pain in the *** for html errors and with automation eventually adds corruption to my database with truncated info and such...
deepac7 9 Posted February 4, 2025 Posted February 4, 2025 13 hours ago, mickle026 said: Thanks for the link it clarifys a few things for me. I will consider this, as its do-able, but is there any other sites than data 18 where i could get this info?, data 18 is a pain in the *** for html errors and with automation eventually adds corruption to my database with truncated info and such... So far all I could find is data18 which supports scenes in a proper manner. In fact, I came across your plugin because I was using different combination on google search to find an emby plugin that supports data18 and IAFD
mickle026 653 Posted February 6, 2025 Author Posted February 6, 2025 Just a quick warning that the ADM server might go down for a few hours today between 11.30am and 4pm GMT. Building work in the room it is at. If it does it will be back online later.
Nepofigist 0 Posted February 6, 2025 Posted February 6, 2025 Hi, thank you for great plugin. I'm using Emby in docker (config folder is mounted, permissions are okay). I tried to install ADM plugin by adding the DLL file to relevant folder and restarting emby server. Did that, but the plugin is still not visible anywhere in Emby — neither in plugin section nor in sidebar. Could you please advise me what should I do? Thank you!
mickle026 653 Posted February 6, 2025 Author Posted February 6, 2025 (edited) On 13/01/2025 at 20:01, roykurasagi1402 said: For Anyone on TrueNas before installing Emby make a dataset for emby and when you install emby point it to that dataset and then this plugin will work. I dont know anything about docker, but I imagine its similar to truenas (jails and datasets). The quote above is from as user that has that. Also, the windows version of emby has two plugins folders, on windows it needs to reside in the "\programdata\pulgins" folder and not the system one. BTW: ADM Server is back online Edited February 6, 2025 by mickle026
Nepofigist 0 Posted February 6, 2025 Posted February 6, 2025 (edited) On 09/10/2024 at 19:57, c0ldian said: What‘s the current access key?I can’t scrape using the key 15-05-2024, and plugin shows that Have the same issue. I'm from Cyprus, accessing via Starlink. Logs: 06.Feb.2025 - 17.35.04 Local MovieList doesn't Exist! 06.Feb.2025 - 17.35.04 Remote File Doesn't Exist!: http://<ADM Server>/MovieList.txt Also, successfully installed the plugin, so please ignore my previous message. Edited February 6, 2025 by Nepofigist
mickle026 653 Posted February 6, 2025 Author Posted February 6, 2025 (edited) 20 minutes ago, Nepofigist said: Have the same issue. I'm from Cyprus, accessing via Starlink. Logs: 06.Feb.2025 - 17.35.04 Local MovieList doesn't Exist! 06.Feb.2025 - 17.35.04 Remote File Doesn't Exist!: http://<ADM Server>/MovieList.txt I have just checked and can access it remotely, It does exist. Maybe it cannot save it? can it write to your cache folder? or Check the "my plugins for emby server" link in the footer of my messages, its on the same server, if you cannot access that then your isp might be blocking you. Try again with a vpn to confim. Edited February 6, 2025 by mickle026
Nepofigist 0 Posted February 6, 2025 Posted February 6, 2025 6 minutes ago, mickle026 said: I have just checked and can access it remotely, It does exist. Maybe it cannot save it? can it write to your cache folder? or Check the "my plugins for emby server" link in the footer of my messages, its on the same server, if you cannot access that then your isp might be blocking you. Try again with a vpn to confim. Thank you, I've succeeded with the access. Now for all movies in my library I've the same log events: 06.Feb.2025 - 18.11.17 [ADMMetadataProvider-GetMetadata-WithYear] ============== NEW SEARCH ============== 06.Feb.2025 - 18.11.17 [ADMMetadataProvider-GetMetadata-WithYear] Independant Year Value Not Supplied! 06.Feb.2025 - 18.11.17 [ADMMetadataProvider-GetMetadata-WithYear] Searchstring: PunishmentfromMorganRainandPaigeOwens_s01_JessyJones_KyleMason 06.Feb.2025 - 18.11.19 [ADMMetadataProvider-GetMetadata-WithYear] This Search found: 0 results. 06.Feb.2025 - 18.11.19 [ADMMetadataProvider-GetMetadata-WithYear] This Search took: 00:00:01.3301122 Seconds
mickle026 653 Posted February 6, 2025 Author Posted February 6, 2025 PunishmentfromMorganRainandPaigeOwens_s01_JessyJones_KyleMason That doesn't seem like a movie, and it's definitely not meeting emby naming conventions. Adm is for movies and vods, but they need to be named correctly.
mickle026 653 Posted February 7, 2025 Author Posted February 7, 2025 (edited) There was a GRID power cut last night (GMT) where the server locations power was cut, first one in years.... odd that it co-incides with it also being off for a few hours but here we are... Anyway, all systems are up and running, internally, everything is fine, systems can communicate all ways (in and out), But the server ip cannot be pinged from external, seems "something" isnt working. Whether its my servers ISP or not, ima a not sure at the moment Please be patient i am looking into it. All sorted Edited February 7, 2025 by mickle026
TwenZi 0 Posted February 27, 2025 Posted February 27, 2025 (edited) Edited February 27, 2025 by TwenZi
TwenZi 0 Posted February 27, 2025 Posted February 27, 2025 (edited) Hello, please tell me the file AdultMovieList.txt has appeared in the cache folder but the plugin does not work, does not create separate log files, tell me where to look??? (windows system) Edited February 27, 2025 by TwenZi
mickle026 653 Posted February 27, 2025 Author Posted February 27, 2025 22 minutes ago, TwenZi said: Hello, please tell me the file AdultMovieList.txt has appeared in the cache folder but the plugin does not work, does not create separate log files, tell me where to look??? (windows system) Have you got it turned on in the individual library settings? Settings>Library>Edit>
TwenZi 0 Posted February 27, 2025 Posted February 27, 2025 (edited) yes Edited February 27, 2025 by TwenZi
mickle026 653 Posted February 27, 2025 Author Posted February 27, 2025 working just fine here. So I have no idea what the problem is there, the logs appear with Emby system logs ion the log directory. Mine is also windows.
TwenZi 0 Posted February 27, 2025 Posted February 27, 2025 (edited) Just checked, deleted and installed Edited February 27, 2025 by TwenZi
justinoh 0 Posted March 15, 2025 Posted March 15, 2025 Anyone else seeing issues with newly added entries missing cover images?
mickle026 653 Posted March 15, 2025 Author Posted March 15, 2025 2 hours ago, justinoh said: Anyone else seeing issues with newly added entries missing cover images? I have not been checking in on the servers scraper because I have been extremely busy elsewhere, I will check it. Is it mainstream ,jav or both?
justinoh 0 Posted March 15, 2025 Posted March 15, 2025 That's okay man, appreciate all the work you've put into the plugin! What I've noticed is JAV from newly added javlibrary links. Metadata is there but not cover images. Thank you!
