halitayarci 13 Posted August 5, 2024 Posted August 5, 2024 (edited) This is the whole file: <html><body onload='resend();'> <script> function resend() { document.cookie="sto-idd=10bdee7e5873cf74; max-age=1; path=/"; window.location.reload(); } </script> </body> </html> After wrting the above message I ried it with VPN running and it updated correctly. So I guess my ISP was blocking... Thank you very much for your help Edited August 5, 2024 by halitayarci Solved
mickle026 653 Posted August 5, 2024 Author Posted August 5, 2024 (edited) 2 hours ago, halitayarci said: This is the whole file: <html><body onload='resend();'> <script> function resend() { document.cookie="sto-idd=10bdee7e5873cf74; max-age=1; path=/"; window.location.reload(); } </script> </body> </html> After wrting the above message I ried it with VPN running and it updated correctly. So I guess my ISP was blocking... Thank you very much for your help That's a first, so far never had it blocked by an isp. Where in the world are you? Edited August 5, 2024 by mickle026
halitayarci 13 Posted August 5, 2024 Posted August 5, 2024 (edited) Turkey By the way do you know any other way to bypass this besides a VPN? It slows the connection and I will have to do the updates manually Edited August 5, 2024 by halitayarci
mickle026 653 Posted August 6, 2024 Author Posted August 6, 2024 No idea why your ISP would even block the url. I use a VPN often (PrivadoVPN) and do not notice any slow down at all, so I guess thats down to how good the VPN provider is.
brimack 0 Posted August 26, 2024 Posted August 26, 2024 I have the latest version installed and enabled in my settings, yet when i make a test folder and put a dozen movies in it i get nothing, just a generated thumbnail, it's not pulling any box covers, or actor info, or anything, i disabled it and went back to using the moviesdb plugin and it got them right away, so what info does this pluging actully get? my collection is 4000+ full lenght movies from the 60s through the 2000's, i'm not using it for clips or single scenes, surely it must have data for films no? if so why isn't anything coming up?
mickle026 653 Posted August 26, 2024 Author Posted August 26, 2024 First of all make sure you put in the correct access key in the settings, then turn on all the logs and verify its contacting the server. Read above, there are a few people that had different issues, the server is operational and works fine. Make sure it is turned on as a fetcher in the library settings (Metadata and Images) Check the server cache folder, see if there is an ADM folder and that in it is a file called \ADM\AdultMovieList.txt, this will contain the current movies that it can find. The list auto updates on demand and is needed by the plugin. This can be opened with a suitable text editor for large files. If the access key is missing or the cahed file is not downloading you will get nothing, can you identify and find anything? - access key is in post 1 Sounds to me like one of the above is not happening The Database is currently over 630,000 Movies - it fetches all the info I have, Poster, Actors, Directors etc - many actors with images. Mainstream (American, Europe, German etc) JAV, VOD, and others. Most JAV (and there is a lot) though doesnt have a description, Just the poster and actors. The database is still growing and may or may not contain the titles you are looking for, this is an English Language plugin.
fangorious 1 Posted September 6, 2024 Posted September 6, 2024 Just to confirm/double-check, this provider site/DB doesn't have any data for content from tube sites like PornHub/xHamster/XVideos or sites like ManyVids/Fansly, correct?
mickle026 653 Posted September 6, 2024 Author Posted September 6, 2024 52 minutes ago, fangorious said: Just to confirm/double-check, this provider site/DB doesn't have any data for content from tube sites like PornHub/xHamster/XVideos or sites like ManyVids/Fansly, correct? Correct. DVDs and VODs only. 1
mickle026 653 Posted September 20, 2024 Author Posted September 20, 2024 (edited) ADM is currently offline due to hardware failure. I cannot offer an eta for it to be back online at present because i dont know yet what has died and what needs replacing. Its been online for almost 2 years with only 2 short outages so far.... Please be patient Thank for your understanding Back Online ! Took it apart blew it, put it back together ... workjing again ... Edited September 21, 2024 by mickle026 1 2
mankio 0 Posted September 22, 2024 Posted September 22, 2024 @mickle026First of all, thank you for your hard word. I just wanna ask you how can we add trailers.
mickle026 653 Posted September 22, 2024 Author Posted September 22, 2024 ADM doesn't do trailers at all at the moment, but emby itself does support them if you put them in your media directory with the movie like this: Filename-trailer.mp4 And then refresh that item so it gets picked up and added to the database. It will then appear in the detail screen. 1
c0ldian 0 Posted October 9, 2024 Posted October 9, 2024 What‘s the current access key?I can’t scrape using the key 15-05-2024, and plugin shows that Quote There are currently (unknown) Movie entries in the database.
mickle026 653 Posted October 9, 2024 Author Posted October 9, 2024 2 minutes ago, c0ldian said: What‘s the current access key?I can’t scrape using the key 15-05-2024, and plugin shows that That is the current access key. I can access it fine here. Check your cache folder has a folder in it called ADM and iside that is a file called AdultMovieList.txt
c0ldian 0 Posted October 9, 2024 Posted October 9, 2024 5 minutes ago, mickle026 said: That is the current access key. I can access it fine here. Check your cache folder has a folder in it called ADM and iside that is a file called AdultMovieList.txt The ADM folder is empty, should I create the file named AdultMovieList.txt? The Update Database button seems it does not work well, though showing Update MovieList was Successful!
mickle026 653 Posted October 9, 2024 Author Posted October 9, 2024 No, it'll create it automatically. What you need to know is why you cannot download the update. What country are you? I had 1 person in Turkey report similar, and it turned out his ISP was blocking the IP of the server. Some others with reverse proxies had problems also. I can add that update file here but its no use if you cannot access my server for the metadata either. What does Log Available Movie List updates say in its log?
c0ldian 0 Posted October 9, 2024 Posted October 9, 2024 6 hours ago, mickle026 said: No, it'll create it automatically. What you need to know is why you cannot download the update. What country are you? I had 1 person in Turkey report similar, and it turned out his ISP was blocking the IP of the server. Some others with reverse proxies had problems also. I can add that update file here but its no use if you cannot access my server for the metadata either. What does Log Available Movie List updates say in its log? China, the Log shows Quote 09.10月.2024 - 16.58.33 Local MovieList doesn't Exist! 09.10月.2024 - 16.58.34 Remote File Doesn't Exist!: http://<ADM Server>/MovieList.txt 09.10月.2024 - 16.58.34 Check Web Accessability/VPN Access... So it seems that I need to Add your server address to the proxy list. What’s your accurate server address or should I capture packages?
mickle026 653 Posted October 10, 2024 Author Posted October 10, 2024 17 minutes ago, c0ldian said: China, the Log shows So it seems that I need to Add your server address to the proxy list. What’s your accurate server address or should I capture packages? I do not have a static address , thats why its a dynamic url. I'll pm it to you.
acer1204 3 Posted October 24, 2024 Posted October 24, 2024 hi,i use admv2, but the cover is good,file not change. how to fix it or i lose some setting?
mickle026 653 Posted October 24, 2024 Author Posted October 24, 2024 4 hours ago, acer1204 said: but the cover is good,file not change. Please clarify what you mean?
Guest Posted November 30, 2024 Posted November 30, 2024 Can someone please let me know how I go about installing the adult metadata plug in. I cant find any instructions for it. Im using a Mac. Any guidance would be appreciated Thank you
kikinjo 294 Posted December 12, 2024 Posted December 12, 2024 @mickle026 Great plugin ! i would kindly request a feature for the plugin. Option in plugin to define a folder NOT to scan. Exclude it from scanning so we can include in library for example website rips and similar.
roykurasagi1402 1 Posted January 13, 2025 Posted January 13, 2025 Good day ive been trying to install this plugin in TrueNas and i put it into the plugin folder but it wont recognize it has anyone had any luck on TrueNas?
roykurasagi1402 1 Posted January 13, 2025 Posted January 13, 2025 For Anyone on TrueNas before installing Emby make a dataset for emby and when you install emby point it to that dataset and then this plugin will work. 1
biziker4 0 Posted January 14, 2025 Posted January 14, 2025 I cant figure out how to instal this plugin, I have it installed on a mycloud ultra ex2, and cant find a way to access the program files, any ideas?
mickle026 653 Posted January 14, 2025 Author Posted January 14, 2025 13 hours ago, biziker4 said: I cant figure out how to instal this plugin, I have it installed on a mycloud ultra ex2, and cant find a way to access the program files, any ideas? No Idea But its a NAS, so you probably have to find the plugins dir, ssh into it and copy it there and set permissions.
