MarauderEMBY 17 Posted February 23, 2024 Posted February 23, 2024 (edited) Yes, I have tested a few, but I literally have thousands to complete first...LOL So far there has been success finding several using just the main titles (that also was how I ran across the 'genre' issue). BelAmi Premiere Collection - Gods of Porn was one of those... For example, it does not contain any female actor/models BUT as you see below. It also is an international and highly accredited studio... not amateur. Also was hesitant, at this stage because I had to manually edit these back and go with what I had embedded instead, each one of these items shows up in my genre listing until I fix it. Edited February 23, 2024 by MarauderEMBY
mickle026 653 Posted February 23, 2024 Author Posted February 23, 2024 I have removed these from this particular title in the database. 1
leandromsj 0 Posted April 1, 2024 Posted April 1, 2024 Hello. Is this plugin still working? I click on "Obtain a Key" and it leads me to a very sus website... Can someone help? Thanks.
mickle026 653 Posted April 1, 2024 Author Posted April 1, 2024 58 minutes ago, leandromsj said: Hello. Is this plugin still working? I click on "Obtain a Key" and it leads me to a very sus website... Can someone help? Thanks. The obtain a key link doesn't work, the website it went to doesn't exist anymore , you don't need a key I currently provide a free key in the first post, I think it was 1234, but check that post and it's there. 1
shiftytrees 3 Posted April 19, 2024 Posted April 19, 2024 (edited) @mickle026Hate to bug you again dude, but I think I may have a prob. I had to recreate my library because it became corrupted. Now when it scans library I think it just gets stuck. I've let it go for days, but when it gets to my jav collection (I only have it set up for my javs so this is the only collection the plugin accesses) it just hangs and doesnt budge. This is from the embyserver log: Quote 2024-04-18 14:42:32.855 Error ProviderManager: ADMImageProvider failed in GetImageInfos for type Movie *** Error Report *** Version: 4.8.3.0 Command line: C:\Users\XXXXX\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\XXXXX\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22000 Framework: .NET 6.0.27 OS/Process: x64/x64 Runtime: C:/Users/XXXXX/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\XXXXX\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\XXXXX\AppData\Roaming\Emby-Server\system System.ArgumentException: System.ArgumentException: String cannot be of zero length. (Parameter 'oldValue') at System.String.Replace(String oldValue, String newValue) at ADMv2.ADMImageProvider.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetImages(RemoteImageFetchOptions options, CancellationToken cancellationToken, IRemoteImageProvider provider, Int32 providerIndex) Source: System.Private.CoreLib TargetSite: System.String Replace(System.String, System.String) Idk if its something I did or what, but I'd appreciate any help on this Edited April 19, 2024 by shiftytrees
mickle026 653 Posted April 19, 2024 Author Posted April 19, 2024 1 hour ago, shiftytrees said: @mickle026Hate to bug you again dude, but I think I may have a prob. I had to recreate my library because it became corrupted. Now when it scans library I think it just gets stuck. I've let it go for days, but when it gets to my jav collection (I only have it set up for my javs so this is the only collection the plugin accesses) it just hangs and doesnt budge. This is from the embyserver log: Idk if its something I did or what, but I'd appreciate any help on this Use the Plugin attached, I added some debug code and an error trap so that it will continue with the library scan, just skip the movie its having an issue with and report it in the ADM logs. Can you turn on all the ADM logs and reproduce this and send them in pm if you dont want to post them? The new DLL will report "[ADMImageProvider-GetImages] Exeception Thrown!" - where this happens and should state the movie name too. That error should not occur, but in the code where that might happen is if a file or folder might be recognised as having the year value twice in the name. Like so: Moviename (YYYY)(YYYY) ADMv2(19-04-2024).zip 1
shiftytrees 3 Posted April 19, 2024 Posted April 19, 2024 2 hours ago, mickle026 said: Use the Plugin attached, I added some debug code and an error trap so that it will continue with the library scan, just skip the movie its having an issue with and report it in the ADM logs. Can you turn on all the ADM logs and reproduce this and send them in pm if you dont want to post them? The new DLL will report "[ADMImageProvider-GetImages] Exeception Thrown!" - where this happens and should state the movie name too. That error should not occur, but in the code where that might happen is if a file or folder might be recognised as having the year value twice in the name. Like so: Moviename (YYYY)(YYYY) ADMv2(19-04-2024).zip 61.93 kB · 0 downloads thanks, I just installed the addon and am gonna let it run the library scan tonight while I sleep and see what happens tomorrow. I already have all of the logs on so once its done I can either post em here or pm you, im fine with either or
Zaizu07 0 Posted April 27, 2024 Posted April 27, 2024 I have content that has metadata on adultempire that isn't being pulled via Identify. I think it's because it's listed as a VOD and not a DVD. Is it possible to have VOD's metadata pulled as well?
mickle026 653 Posted April 27, 2024 Author Posted April 27, 2024 28 minutes ago, Zaizu07 said: I have content that has metadata on adultempire that isn't being pulled via Identify. I think it's because it's listed as a VOD and not a DVD. Is it possible to have VOD's metadata pulled as well? This plugin does not pull from Adultdvdempire or any other adult sitre for that matter, it uses its own database. However data can be fetched from adultdvdempire to the plugins database if it fits the criteria. pm me the links to the content you want added, some vod is ok if its actually same as a dvd and has a poster (box) image, but individual scenes wont be added.
mickle026 653 Posted April 28, 2024 Author Posted April 28, 2024 The movies you sent me via pm should all be searchable via ADM now. If there are more please send me (pm) a plain text file (notepad or similar) with 1 http(s) link per line, thanks
mickle026 653 Posted May 16, 2024 Author Posted May 16, 2024 (edited) Updated DLL - please read post 1 update info and update your dll file Many thanks Edited May 16, 2024 by mickle026
Roger7777777 0 Posted May 16, 2024 Posted May 16, 2024 2 hours ago, mickle026 said: Updated DLL - please read post 1 update info and update your dll file Many thanks Thx bro. But no content in the access key file.
mickle026 653 Posted May 16, 2024 Author Posted May 16, 2024 (edited) Re-uploaded to 1st post - apologies for that Edited May 16, 2024 by mickle026
gerlong 0 Posted June 4, 2024 Posted June 4, 2024 can you explain how to install this step by step? I can't find it in the Plugins Catalog. Thanks.
mickle026 653 Posted June 4, 2024 Author Posted June 4, 2024 It's not in the catalogue. Please read post 1 carefully! You may need to read further if you don't find everything you need there it's all in this thread. Download the zip file Extract the dll. Copy the dll to the plugins folder (method depends on platform) Reboot the emby server application Input the access key from post 1 of this thread in adm settings and choose the options you wish to use. Without the personal access key you cannot download anything, just lookup/identify without it, but not apply your results. Enable in the library settings as metadata and image fetchers and set it's priority to what you want it to be . Save the settings! Please bear in mind it's not perfect, but it's probably the best there is at the moment . Pornhub also have a plugin for emby, you can find details for that in this thread somewhere too, I do believe they made theirs members only now though and moved their data server.
Sid10 0 Posted July 11, 2024 Posted July 11, 2024 @mickle026 thanks for a superb bit of work, migrated from plex and missing a good few titles, does the request feature work the same as sending you a pm? Thanks again
mickle026 653 Posted July 11, 2024 Author Posted July 11, 2024 It does work but it's not instant, the links get added to a queue but as priority. They should be available within 24hrs, items that are already in the database will not be added again, some People add links for items that are already there, in these cases the movie names don't match well enough or the naming convention is too difficult or 3rd thing emby is good at stripping anything after what it thinks is a rating even if it's not. Name your files well, check identify, then request. Also a list via pm if that doesn't work.
halitayarci 13 Posted August 5, 2024 Posted August 5, 2024 (edited) Hello I tried to follow the instructions but I think the plugin doesnt work in my system. Emby server runs on my Win11 PC and when I update the database there is no error message. Still number of movies shows only "9" and for the library which ADMv2 is set as metadata provider "identify" doesn't bring any results... I tried at least for 20 different titles... What do you think I am doing wrong? Edited August 5, 2024 by halitayarci
mickle026 653 Posted August 5, 2024 Author Posted August 5, 2024 14 minutes ago, halitayarci said: Hello I tried to follow the instructions but I think the plugin doesnt work in my system. Emby server runs on my Win11 PC and when I update the database there is no error message. Still number of movies shows only "9" and for the library which ADMv2 is set as metadata provider "identify" doesn't bring any results... I tried at least for 20 different titles... What do you think I am doing wrong? There was a problem with the server today, so maybe it's because of that. Go to your emby cache folder (location depends on system settings), in there will be a folder called ADM, inside that folder delete the movie list files, or the contents of that folder, at next run it will redownload the server file list. I.e next check or identify etc. Alternatively, it'll download a new list tomorrow anyway, you can just wait until then and it'll correct itself.
mickle026 653 Posted August 5, 2024 Author Posted August 5, 2024 I just checked and there is currently 625,789 titles in the database. This amount will increase. A fresh update of the AdultMovieList.txt file in the cache folder will give access to all of them. Just manually delete the curernt one to force an update.
halitayarci 13 Posted August 5, 2024 Posted August 5, 2024 Thank you for the reply. I deleted the cache as you mentioned and forced an update... Nothing changed... The same "9" screens is there...
mickle026 653 Posted August 5, 2024 Author Posted August 5, 2024 36 minutes ago, halitayarci said: Thank you for the reply. I deleted the cache as you mentioned and forced an update... Nothing changed... The same "9" screens is there... Open the adultmovielist.txt file in the cache and see if it has only 9 lines in it, it sounds strange. The number you see is a line count of the file. I tested before posting and am getting as I posted over 625,000 lines. File is 15.3mb at the moment. So because it's still 9, it seems suspicious like it either didn't delete or your download is being stopped? 1
