VirulentPip 93 Posted October 3, 2022 Author Posted October 3, 2022 Beta Driver D3D9 and D3D11 are options but H265 > H264 fails and falls back to software transcode. Then tried Standard 31.0.101.3277 - Blazing speed with D3D11 - Chrome has a spinning blue circle that doesn't go away but it's playing. 4K loading circle not present UHD 770 was 190fps so with 4K the Arc is slightly slower (on par) but smashes the UHD 770 at 1080p. Drivers do definitely cause a lot of issues it seems, although the Arc has blistering speeds at 1080p, I'll be switching back to the UHD 770 due to needing the Arc for my AV1 encoding. But for those without those needs, seems like a good card to get your hands on. 2
TMCsw 259 Posted October 5, 2022 Posted October 5, 2022 @VirulentPipJust curious!? While I understand it will take a while for Intel to get a decent driver set for this new-ish card and understandably a little longer for emby to support it (because of this and so far very few people are trying to use it), I ask the following because the best reason for me to get this card (or next version) would be for the AV1 encoding ability/speed (as I already have UHD 770) So.. ..do you have any performance info in regards to AV1 encoding speed/quality for this card (via. ffmpeg, handbrake or otherwise)? All the reviews i can find online just say trans-coding is good but only talk about the mediocre game performance. TIA.
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 (edited) 7 hours ago, TMCsw said: So.. ..do you have any performance info in regards to AV1 encoding speed/quality for this card (via. ffmpeg, handbrake or otherwise)? All the reviews i can find online just say trans-coding is good but only talk about the mediocre game performance. Yep, I have been using Handbrake Nightly (Prod release doesn't have QSV AV1 yet) AV1 10bit- ICQ 20 (28 for cartoons) Quality and I also use the automatic crop option, no other video options or filters. Blues Brothers Extended Cut: Quality and size pretty much comparable with x265 encodes I used to do a while back (from memory that is no side-by-side comparisons) Never thought while checking "Ah I could probably check a couple ICQ lower. I've not checked the PQ of this one yet, but I started 2 Fast 2 Furious (4K HDR) last night: Quite a lot slower, but still a LOT faster than software x265 - I'll edit post once I've checked PQ on my TV - To be fair I'm only expecting do to this for 4K films that I like to have in the format but aren't absolute musts. Edit -- Hmm even though it's carried over the BT.2020 It's not HDR, will have to check more Handbrake settings. Edit 2 - Ah so me manually putting the filter to BT.2020 enabled tone mapping, left that alone. Holy moly, surprisingly very watchable, watched the opening race and didn't notice any artefacts, I'd probably use ICQ 16 just for the sake of it though. Overall, very impressed. Edited October 5, 2022 by VirulentPip 2
rbjtech 5341 Posted October 5, 2022 Posted October 5, 2022 Thanks for the updates .. ~2x real time for 4K looks mighty impressive - is that a 4k remux source (60-80Mbit/h265) to 6.5 Mbit/av1 ?
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 1 minute ago, rbjtech said: ~2x real time for 4K looks mighty impressive - is that a 4k remux source (60-80Mbit/h265) to 6.5 Mbit/av1 ? Source 1
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 (edited) @rbjtech Are my eyes or emby lying to me or is this TV direct playing back AV1 10 bit? Wow it actually does support. Edited October 5, 2022 by VirulentPip 2
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 But a Samsung Q60A transcodes. Surely it couldn't have been a fluke? QE55Q60A QE55Q60A ffmpeg-transcode-9a47e25f-d154-460c-a2f2-fdf64752da3c_1.txt
Luke 42237 Posted October 5, 2022 Posted October 5, 2022 2 minutes ago, VirulentPip said: But a Samsung Q60A transcodes. Surely it couldn't have been a fluke? QE55Q60A QE55Q60A ffmpeg-transcode-9a47e25f-d154-460c-a2f2-fdf64752da3c_1.txt 86.23 kB · 0 downloads That's an older version of our app, so in that build we're probably not even checking for av1 compatibility.
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 1 minute ago, Luke said: That's an older version of our app, so in that build we're probably not even checking for av1 compatibility. But the one above is the same version 1.2.6 and to my amazement played back fine.
Luke 42237 Posted October 5, 2022 Posted October 5, 2022 10 minutes ago, VirulentPip said: But the one above is the same version 1.2.6 and to my amazement played back fine. OK maybe we had added it in 1.2.6.
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 3 minutes ago, Luke said: OK maybe we had added it in 1.2.6. Just odd that one will playback fine and the other won't also for the Q60A, on the app store it says Latest Version 1.2.6 (1.2.6 Installed) so I guess they aren't being pushed anymore?
Luke 42237 Posted October 5, 2022 Posted October 5, 2022 Just now, VirulentPip said: Just odd that one will playback fine and the other won't also for the Q60A, on the app store it says Latest Version 1.2.6 (1.2.6 Installed) so I guess they aren't being pushed anymore? Updates are still being pushed to the store.
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 Just now, Luke said: Updates are still being pushed to the store. They uninstalled and it still grabbed the 1.2.6 on reinstall lol.. UK based. Not sure if that's something that needs to be looked into?
Happy2Play 9811 Posted October 5, 2022 Posted October 5, 2022 @VirulentPip Did you play the same media on both devices? &TranscodeReasons=DirectPlayError Will guess do to media not having frame rate of 60?
VirulentPip 93 Posted October 5, 2022 Author Posted October 5, 2022 Tried the same file for science on the Q60A @Happy2Play Andor S01E05 as above in screenshot ffmpeg-transcode-0631d5a5-b414-4612-99ca-3c462e0671cb_1.txt
Happy2Play 9811 Posted October 5, 2022 Posted October 5, 2022 (edited) @FrostByte@SamESmay have to comment on the differences and possible cause on one throwing "TranscodeReasons=DirectPlayError". QE55Q60AAUXXU (2021) UE50TU7020KXXU (2020) Edited October 5, 2022 by Happy2Play
SamES 1084 Posted October 6, 2022 Posted October 6, 2022 12 hours ago, Happy2Play said: @FrostByte@SamESmay have to comment on the differences and possible cause on one throwing "TranscodeReasons=DirectPlayError". QE55Q60AAUXXU (2021) UE50TU7020KXXU (2020) Normally this error means we expected the file to DirectPlay, and the player tried it but failed. Generally, this might be an error with the file (encoding, container, etc) or an incompatible encoding setting that we are not checking for but is not supported by the player
VirulentPip 93 Posted October 6, 2022 Author Posted October 6, 2022 5 minutes ago, SamES said: Normally this error means we expected the file to DirectPlay, and the player tried it but failed. Generally, this might be an error with the file (encoding, container, etc) or an incompatible encoding setting that we are not checking for but is not supported by the player Can’t be error with the file if the TU7020 direct played and the Q60A didn’t surely? The TU7020 uses older version of Tizen, but you’d imagine the older one to have the issues right?
rbjtech 5341 Posted October 6, 2022 Posted October 6, 2022 14 minutes ago, VirulentPip said: Can’t be error with the file if the TU7020 direct played and the Q60A didn’t surely? The TU7020 uses older version of Tizen, but you’d imagine the older one to have the issues right? This is the source created by the A380 yes ? If possible, can you sample a small section of it and post via PM ? I'd like to see if my FireTV/Shield clients are going to like AV1 decode before I splash on the card ...
SamES 1084 Posted October 6, 2022 Posted October 6, 2022 50 minutes ago, VirulentPip said: Can’t be error with the file if the TU7020 direct played and the Q60A didn’t surely? The TU7020 uses older version of Tizen, but you’d imagine the older one to have the issues right? Yes, that's what you'd expect, but funny things can happen between Tizen releases. Some 2021 models support 120fps, but only 60fps for 2020 models. They have changed this so it's possible they've changed (or broken) other things as well!
VirulentPip 93 Posted October 9, 2022 Author Posted October 9, 2022 (edited) The Q60T direct plays back too. But it’s juddering, I expect this is due to lack of HW acceleration, I assume the other TV is too but not being reported. Is there anyway I can force a transcode, can’t see Convert option, which is how I’d assume to do that. Can I edit a device config or something that will tell server it cannot play AV1? Edited October 9, 2022 by VirulentPip
SamES 1084 Posted October 9, 2022 Posted October 9, 2022 3 hours ago, VirulentPip said: The Q60T direct plays back too. But it’s juddering, I expect this is due to lack of HW acceleration, I assume the other TV is too but not being reported. Is there anyway I can force a transcode, can’t see Convert option, which is how I’d assume to do that. Can I edit a device config or something that will tell server it cannot play AV1? Easiest option is to drop the playback quality until it starts transcoding, but remember to change it back to auto as this will affect all playbacks
VirulentPip 93 Posted October 9, 2022 Author Posted October 9, 2022 But the AV1 files are like 2-4Mbps.
Happy2Play 9811 Posted October 9, 2022 Posted October 9, 2022 @SamES OT: Does not currently exist in all clients/apps. But believe all clients/app should add Playback Correction that toggles media playback from Direct Play to Direct Stream to Transcode without adjusting quality.
SamES 1084 Posted October 10, 2022 Posted October 10, 2022 59 minutes ago, Happy2Play said: @SamES OT: Does not currently exist in all clients/apps. But believe all clients/app should add Playback Correction that toggles media playback from Direct Play to Direct Stream to Transcode without adjusting quality. Yes, that would be useful. A decision that @Lukewould need to make
