denzoid 57 Posted August 22, 2022 Posted August 22, 2022 (edited) Solved- I just had to install the XmlTV addon. This is my first attempt to get live tv (with an M3U playlist) working and can't figure out how to get the EPG to work, I can view channels and view live TV but the guide is empty. The instructions I have found do not relate to the setting/menus I am seeing in Emby. I do not see anywhere to input a guide (xml) url and when I go through the guide settings the dropdown is empty. If someone can point me to a guide or let me know what I am doing wrong I'd really appreciate it. Thanks! Edited August 22, 2022 by denzoid Solution found
EODCrafter 181 Posted August 22, 2022 Posted August 22, 2022 Seems to be a glitch, my dropdown asks me to select a xmltv file or emby guide data then I just put in the zipcode and the guide populates.
Luke 42243 Posted August 25, 2022 Posted August 25, 2022 Quote Solved- I just had to install the XmlTV addon. This is included with Emby Server installations out of the box, so you must have uninstalled it at some point. Thanks for following up. 1
