ZGTNM 0 Posted August 21, 2022 Posted August 21, 2022 So, I am now trying to use Emby on my synology, besides plex... unfortunatly after all installed, up to the latest version (Version 4.8.0.8 for Synology), and also after giving all permissions as per information also from the forums with "System Internal User" emby with the "Read/Write permission" to the movies shared folder, and after adding it to emby as being my Library "/volume3/AV Media", it simply continues to give 0 Items, with the info of "No items found." ... Which should not be, since all subdirectories with all movies are there, and plex have no issues loading/updating with the library, of this same movies/directories... Can you inform/help of what other options i can try to be able to have my movies added/played to emby (how can Emby Server say 0 items in Library, if all is there and all permissions are given) ? Tks in advance...
Happy2Play 9812 Posted August 22, 2022 Posted August 22, 2022 Can you provide a server log. How to Report a Problem
ZGTNM 0 Posted August 22, 2022 Author Posted August 22, 2022 Sure thing, here it is then... embyserver-63796725830.txt
Happy2Play 9812 Posted August 22, 2022 Posted August 22, 2022 Sorry that log doen't really show anything library related only a PortMapper issue. Can you do a full library scan and post another log to see if it shows more info.
Luke 42243 Posted August 23, 2022 Posted August 23, 2022 hi @ZGTNM how many Emby libraries have you created, and what folder paths did you add to each one?
ZGTNM 0 Posted August 23, 2022 Author Posted August 23, 2022 13 hours ago, Happy2Play said: Sorry that log doen't really show anything library related only a PortMapper issue. Can you do a full library scan and post another log to see if it shows more info. Maybe this is the right log ... embyserver(1).txt
Happy2Play 9812 Posted August 23, 2022 Posted August 23, 2022 I see two issue Permissions and iNotify. Need to look at recursive permissions on this library 2022-08-23 10:50:47.704 Error BaseItem: Error validating children for AV Media 63 /volume3/AV Media Permission denied Need to adjust iNotify values. 2022-08-23 10:50:50.479 Error LibraryMonitor: Error in Directory watcher for: /volume3/AV Media The configured user limit (8192) on the number of inotify watches has been reached, or the operating system failed to allocate a required resource. 1
Luke 42243 Posted August 24, 2022 Posted August 24, 2022 It looks like the server does not have permission to read the contents under /volume3/AV Media Have you taken a look at this?
FrostByte 5454 Posted August 24, 2022 Posted August 24, 2022 14 minutes ago, ZGTNM said: Hi Luke, it is active the Read/Write: Did you check the file and folder permissions at the system level also?
ZGTNM 0 Posted August 24, 2022 Author Posted August 24, 2022 On 23/08/2022 at 20:08, Happy2Play said: I see two issue Permissions and iNotify. Need to look at recursive permissions on this library 2022-08-23 10:50:47.704 Error BaseItem: Error validating children for AV Media 63 /volume3/AV Media Permission denied Need to adjust iNotify values. 2022-08-23 10:50:50.479 Error LibraryMonitor: Error in Directory watcher for: /volume3/AV Media The configured user limit (8192) on the number of inotify watches has been reached, or the operating system failed to allocate a required resource. I also did this, as per info, it continues to show 0 on library, but if i add just one movie, it shows ok... I guess emby then limited to the amount of files it can load, even with this RTM fix...
Happy2Play 9812 Posted August 24, 2022 Posted August 24, 2022 10 minutes ago, ZGTNM said: I also did this, as per info, it continues to show 0 on library, but if i add just one movie, it shows ok... I guess emby then limited to the amount of files it can load, even with this RTM fix... No as the iNotify issue only applies to Realtime Monitoring. So, a normal library scan would find media. But appears the overall issue is Permissions unless a new log shows us something different. 1
