max28 1 Posted August 21, 2022 Posted August 21, 2022 Hi, Could you had volume and brightness control on android app, like vlc and other ? I think jellyfin has it ? Thx
seanbuff 1356 Posted August 22, 2022 Posted August 22, 2022 We used to have gesture based controls in the old Android app, but they were removed due to too many complaints. Already been discussed here:
Luke 42243 Posted August 22, 2022 Posted August 22, 2022 They are likely to return in future updates, just presented a little differently. 1
max28 1 Posted August 22, 2022 Author Posted August 22, 2022 At least, add them disable by default if needed. No one is complaining on vlc... Thx 1
Solution Luke 42243 Posted September 3, 2022 Solution Posted September 3, 2022 Hi, brightness control will be back in the video player in the next updates to the Emby Android and iOS apps. Thanks. 1
DarKni8 41 Posted September 13, 2022 Posted September 13, 2022 I see they are in beta changelog. How can they be triggered?
Luke 42243 Posted September 13, 2022 Posted September 13, 2022 Brightness is directly on the OSD similar to netflix, so it should be obvious.
Squash_Konrad 0 Posted January 5, 2023 Posted January 5, 2023 Hi, Unfortunetly Brightness controll is still NOT working how can I change it?
Luke 42243 Posted January 5, 2023 Posted January 5, 2023 15 minutes ago, Squash_Konrad said: Hi, Unfortunetly Brightness controll is still NOT working how can I change it? Hi, we'll take another look at it. Thanks. 1
