icedragonslair 10 Posted August 21, 2022 Posted August 21, 2022 I an constantly having to pause on what I am watching and if it is a prolonged pause and it is anywhere near the last few minutes of a show, it just marks it as watched and moves to the next episode when it is started up again. Is there a way to adjust the resume percentages since they no longer appear in the playback page in the settings? Unraid w/ emby v 4.7.6
GrimReaper 4898 Posted August 21, 2022 Posted August 21, 2022 That is per-library setting, Settings>Library tab>edit desired library, scroll all the way to the bottom.
icedragonslair 10 Posted August 25, 2022 Author Posted August 25, 2022 On 8/21/2022 at 1:45 PM, GrimReaper said: That is per-library setting, Settings>Library tab>edit desired library, scroll all the way to the bottom. Thanks Loads 2 hours ago, Luke said: hi @icedragonslair has this helped? I will let you know, just changed the settings 1
icedragonslair 10 Posted August 26, 2022 Author Posted August 26, 2022 On 8/25/2022 at 12:08 AM, Luke said: hi @icedragonslair has this helped? Yes it did Luke, Thanks loads, Ice 1
