MrDDream 0 Posted August 20, 2022 Posted August 20, 2022 Bonjour, J'ai un problème pour afficher les acteurs sur mes applications Emby. Sur plusieurs centaines de photos d'acteurs, 1 sur X apparaît (sauf quand je clique sur l'acteur pour faire une retouche ou quand je mets à jour manuellement chaque photo). J'utilise la dernière version d'Emby et de TinyMediaManager pour les métadonnées. Merci d'avance pour votre aide ---- Hello, I'm having a problem displaying actors on my Emby apps. Out of several hundred photos of actors, 1 in X appears (except when I click on the actor to do an edit or when I manually update each photo). I use the latest version of Emby and TinyMediaManager for metadata. Thank you in advance for your help
Abobader 3491 Posted August 20, 2022 Posted August 20, 2022 Hello MrDDream, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
ebr 16354 Posted August 20, 2022 Posted August 20, 2022 Hi. We do not use the ".actors" folder under specific shows for people images because these are "character art" as opposed to a generic image of that actual actor. Please see: Media Preparation
MrDDream 0 Posted August 20, 2022 Author Posted August 20, 2022 Thanks for this answer, while searching I saw this on the forum, but even unchecking this option TMM keeps copying in .actors
Luke 42290 Posted August 20, 2022 Posted August 20, 2022 Try refreshing the metadata on a movie or series and see if that helps pull in images for the actors.
MrDDream 0 Posted August 20, 2022 Author Posted August 20, 2022 updated doesn't change anything, and can't disable download in .actor
Luke 42290 Posted August 20, 2022 Posted August 20, 2022 Can't disable .actor - isn't that something to report to tmm? That's not related to emby. Anyway what metadata fetchers are enabled on the library and in what order? Did you check the metadata editor to make sure the metadata isn't locked? Tmm might me writing the nfo with lockdata applied. That means you need to manually unlock in emby first if that's the case.
MrDDream 0 Posted August 20, 2022 Author Posted August 20, 2022 (edited) Yes, I will post on the TMM forum for this issue. But I just realized that Emby "stores" in its configuration the images when I update them by hand (from emby for each actor) I checked the NFO is not locked. Edited August 20, 2022 by MrDDream add information
MrDDream 0 Posted August 20, 2022 Author Posted August 20, 2022 I found a solution (workaround) I enabled Emby scraping (via TMDB) and refreshed the metadata (added the missing ones), this will write directly to the metadata folder and highlight the photos for me.
Luke 42290 Posted August 22, 2022 Posted August 22, 2022 On 8/20/2022 at 12:41 PM, MrDDream said: I found a solution (workaround) I enabled Emby scraping (via TMDB) and refreshed the metadata (added the missing ones), this will write directly to the metadata folder and highlight the photos for me. That's interesting. Didn't know TMM supported that. Thanks for the feedback.
