navarro152 1 Posted August 18, 2022 Posted August 18, 2022 (edited) I recently moved my emby server to a dockers container on a Synology NAS (to make easier future system updates). However, when I added all my content, I do not see the option to visualize the collections section. I already looked in all the option of the app, with no luck. Any idea what I could be missing? I am adding what I do see on the movies section and the part where I allowed to create collection when 2 movies of the same are detected Thanks in advance Edited August 18, 2022 by navarro152
Luke 42243 Posted August 18, 2022 Posted August 18, 2022 Hi there, try refreshing the metadata on some of your movies and see if that helps create collections. Thanks.
navarro152 1 Posted August 19, 2022 Author Posted August 19, 2022 Thanks @Luke it worked, but only for the ones that I refreshed the metadata. Now I just need to refresh all the metadata for all the movies.
Luke 42243 Posted August 19, 2022 Posted August 19, 2022 30 minutes ago, navarro152 said: Thanks @Luke it worked, but only for the ones that I refreshed the metadata. Now I just need to refresh all the metadata for all the movies. You can do that at the library level. Doing it for a few was just a good test to start with.
navarro152 1 Posted August 22, 2022 Author Posted August 22, 2022 Thank you!!! It works like a charm. Now the collections are back with no hassle 1
