jglazer63 23 Posted August 17, 2022 Posted August 17, 2022 Has this ever been resolved with Samsung? I'd like Emby to load as soon as I turn the TV on. Thanks!
FrostByte 5453 Posted August 17, 2022 Posted August 17, 2022 The closest I think you can get is to go into your Smart Features settings and tell it to start the last app you were running when you turned off your TV. So, if you return to the Emby Home Screen and turn off your TV it will then start Emby the next time you turn on your TV. There's another option to auto start the hub, but that's not quite what you want. It makes it quicker to start Emby from the hub, but it gets in the way if you already turned off your TV with Emby running.
