Luke 42239 Posted August 26, 2023 Posted August 26, 2023 HI, the change in 4.7.14 may help with browser-based playback. The upcoming 4.8 release has more improvements as well. Thanks.
Eddie6411284 43 Posted August 27, 2023 Author Posted August 27, 2023 @Luke Ein Klick auf das Live TV Programm und man die ersten Fehler: Quote *** Error Report *** Version: 4.7.14.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk Operating system: Linux version 4.4.302+ (root@build7) (gcc version 12.2.0 (GCC) ) #64570 SMP Sat Jun 3 00:09:29 CST 2023 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.InvalidOperationException: System.InvalidOperationException: Operation is not valid due to the current state of the object. at Emby.Server.Implementations.Library.LibraryManager.ConvertImageToLocal(BaseItem item, ItemImageInfo image, Int32 imageIndex, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at Emby.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() : : *** Error Report *** Version: 4.7.14.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk Operating system: Linux version 4.4.302+ (root@build7) (gcc version 12.2.0 (GCC) ) #64570 SMP Sat Jun 3 00:09:29 CST 2023 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Exception: System.Exception: Error running ffprobe for "rtsp://192.168.27.243:554/?avm=1&freq=466&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,101,1401,1400,1402,1403,1404,1406,1407,1408" - at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, ReadOnlyMemory`1 cacheKey, Boolean addProbeDelay, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() Vom Klick in Emby bis zum Fehler vergehen mehrere Sekunden. Die gleiche URL in VLC genutzt und in nicht einmal 2 Sekunden ist der TV Stream da und wird fehlerfrei abgespielt. Vielleicht solltet Ihr nochmal in den Code der 4.6 schauen, da hats nämlich funktioniert. Auf weitere Tests habe ich irgendwie schon gar keine Lust mehr. Gruß Eddie
Luke 42239 Posted September 27, 2023 Posted September 27, 2023 On 8/27/2023 at 6:55 AM, Eddie6411284 said: @Luke Ein Klick auf das Live TV Programm und man die ersten Fehler: Vom Klick in Emby bis zum Fehler vergehen mehrere Sekunden. Die gleiche URL in VLC genutzt und in nicht einmal 2 Sekunden ist der TV Stream da und wird fehlerfrei abgespielt. Vielleicht solltet Ihr nochmal in den Code der 4.6 schauen, da hats nämlich funktioniert. Auf weitere Tests habe ich irgendwie schon gar keine Lust mehr. Gruß Eddie Do you still have a 4.6 install by chance? I would be curious to know if our ffmpeg command line with the rtsp url has changed.
Eddie6411284 43 Posted September 28, 2023 Author Posted September 28, 2023 @Luke Nein, ich habe keine 4.6 mehr installiert.
Eddie6411284 43 Posted March 3, 2024 Author Posted March 3, 2024 Auch hier bringt die 4.8 keine Verbesserung. Alternativ habe ich mal Plex installiert und siehe da, sowohl Live TV, als auch Aufnahmen sind mit meiner Hardware plötzlich wieder möglich. Der DVB-C Repeater von AVM wird in Plex erkannt. Der Sendersuchlauf funktioniert direkt in Plex, kein Import von M3U Dateien, EPG hinzugeladen, fertig. Plex ist zwar in zig anderen Bereichen deutlich schlechter, aber die Features, die man dort anbietet, funktionieren bei mir wenigstens. Weniger ist manchmal mehr und verärgert die User weniger, als viele Features, die dann nur halb oder gar nicht funktionieren. Gruß Eddie 1
Luke 42239 Posted March 7, 2024 Posted March 7, 2024 On 3/3/2024 at 8:29 AM, Eddie6411284 said: Auch hier bringt die 4.8 keine Verbesserung. Alternativ habe ich mal Plex installiert und siehe da, sowohl Live TV, als auch Aufnahmen sind mit meiner Hardware plötzlich wieder möglich. Der DVB-C Repeater von AVM wird in Plex erkannt. Der Sendersuchlauf funktioniert direkt in Plex, kein Import von M3U Dateien, EPG hinzugeladen, fertig. Plex ist zwar in zig anderen Bereichen deutlich schlechter, aber die Features, die man dort anbietet, funktionieren bei mir wenigstens. Weniger ist manchmal mehr und verärgert die User weniger, als viele Features, die dann nur halb oder gar nicht funktionieren. Gruß Eddie @Eddie6411284 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! 1
Eddie6411284 43 Posted March 7, 2024 Author Posted March 7, 2024 @Luke Wie oft denn noch? Schaut doch einfach mal in die zig von mir angehängten Logdateien rein. 1
Eddie6411284 43 Posted May 21, 2024 Author Posted May 21, 2024 Moin moin, aufgrund einiger Fehler fand ich Emby ne zeitlang uninteressant für mich. Da jetzt ein für mich wichtiges Feature wieder funktioniert, wollte ich auch mal dem Rest ne Chance geben. Aktuell funktioniert Live TV nicht. In der 4.6 hats mal funktioniert, danach habe ich das aufgrund der Fehler bei der Aufnahme nicht mehr benutzt. Ich weiß also nicht, mit welcher Version das kaputt gegangen ist. Ich habe das auf mehreren Rechnern getestet, immer mit dem Effekt, dass es nicht funktioniert. Anbei mal zwei Testläufe mit Logdateien. Browser Chromium 15:35 Live TV RTL => Feher: Derzeit sind keine kompatiblen Streams verfügbar... Browser Edge 15:40 Live TV RTL schwarzes Bild, kurz Ton => Fehler: Derzeit sind keine kompatiblen Streams verfügbar... Im Logfile beim Test mit Chromium finde ich haufenweise Fehler dieser Art > System.Exception: No video encoder found for 'av1' Daraufhin habe ich gesucht und das hier gefunden: Also habe ich die AV1 Video Erweiterung von Microsoft heruntergeladen und der Test mit Edge bringt den Fehler jetzt nicht. Es funktioniert aber trotzdem nicht. Ne Idee, woran das liegen könnte? Gruß Eddie embyserver.txt ffmpeg-transcode-95f19c6c-c4a9-40d8-885d-7f078cad1d12_1.txt ffmpeg-transcode-90174f38-75d6-4819-b940-827978a93320_1.txt ffmpeg-transcode-c4e9f636-0c8d-44fe-9674-59a8ec7df6b1_1.txt hardware_detection-63851902271.txt
Luke 42239 Posted May 22, 2024 Posted May 22, 2024 Hi, what software is broadcasting the stream? Is rtsp the only option?
Eddie6411284 43 Posted May 22, 2024 Author Posted May 22, 2024 @Luke Das ist eine Fritz!Box 6690 Cable und die generiert die M3U Dateien selber, also ja, es scheint die einzige Option zu sein. VLC hat damit auch keine Probleme, Emby 4.6 hatte die früher mit den generierten M3U Dateien auch nicht. Wie gesagt, danach habe ich das aufgrund anderer Emby Fehler nicht mehr genutzt. Vielleicht hängt dieser Fehler damit zusammen: Gruß Eddie
Luke 42239 Posted May 23, 2024 Posted May 23, 2024 OK I've merged the topics just so that we can keep the discussion together. Thanks.
Eddie6411284 43 Posted May 31, 2024 Author Posted May 31, 2024 @Luke Auf der Suche nach Emby Alternativen nur zum Aufnehmen von TV Sendungen habe ich für meine DiskStation das Paket tvstreamrecord installiert. Zusätzlich habe ich das ffmpeg Paket von hier https://johnvansickle.com/ffmpeg/ und zwar die Version "git master: built on 20240524" dazu kopiert. Mit anderen Versionen habe ich es noch nicht getestet. Folgender Aufruf auf der DS führt reproduzierbar zu fehlerfreien Aufnahmen: Quote ['/volume2/tvstreamrecord/ffmpeg/ffmpeg', '-i', 'rtsp://192.168.178.1:554/?avm=1&freq=466&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=1&pids=0,16,17,18,20,7750,7752,7753,7754,7755,7756,7757,7758,7759', '-y', '-t', '299', '-loglevel', 'fatal', '-map', '0', '-c', 'copy', '-ignore_unknown', '/volume2/tvstreamrecord/20240531114500 - Test.ts'] Im Vergleich dazu, der Emby Aufruf von ffmpeg: Quote ffmpeg -loglevel +timing -y -print_graphs_file "/var/packages/EmbyServer/var/logs/ffmpeg-transcode-95f19c6c-c4a9-40d8-885d-7f078cad1d12_1graph.txt" -copyts -start_at_zero -init_hw_device "vaapi=dev1:/dev/dri/renderD128" -analyzeduration 3000000 -stream_loop -1 -c:v:0 mpeg2video -threads:v:0 1 -hwaccel:v:0 vaapi -hwaccel_device:v:0 dev1 -hwaccel_output_format:v:0 vaapi -noautorotate -i "rtsp://192.168.178.1:554/?avm=1&freq=466&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=1&pids=0,16,17,18,20,7750,7752,7753,7754,7755,7756,7757,7758,7759" -map 0:1 -map 0:3 -sn -c:v:0 h264_vaapi -b:v:0 5000000 -g:v:0 75 -maxrate:v:0 5000000 -bufsize:v:0 10000000 -keyint_min:v:0 75 -r:v:0 25 -profile:v:0 high -c:a:0 copy -metadata:s:a:0 language=ger -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/var/packages/EmbyServer/var/transcoding-temp/5392FB/5392FB.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/5392FB/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/packages/EmbyServer/var/transcoding-temp/5392FB/5392FB_%d.ts" Vielleicht hilft Euch das irgendwie weiter, damit man emby auch endlich wieder zum Aufnehmen nutzen kann. Alternativ könntet Ihr die Parameter ja auch konfigurierbar machen, wie man es bei tvstreamrecord gemacht hat. Wenn ich am WE ganz viel Langeweile habe, packe ich Eure Parameter mal in tvstreamrecord, vielleicht finde ich ja einen Parameter, der zum Problem führt. Gruß Eddie
Fragensteller 9 Posted May 31, 2024 Posted May 31, 2024 Wow - sehe ich das richtig? Das Problem besteht seit 16. August 2022?????
Eddie6411284 43 Posted May 31, 2024 Author Posted May 31, 2024 Ja, das siehst Du leider richtig. Mit Emby 4.6 alles perfekt. Mit Emby 4.7 hat man es kaputt optimiert. Auch die Tatsache, dass man das Feature mit Emby Premiere gekauft hat, spornt die Entwickler nicht wirklich an, den Bug zu beheben. Gruß Eddie
Teddyknuddel 136 Posted May 31, 2024 Posted May 31, 2024 1 hour ago, Fragensteller said: Wow - sehe ich das richtig? Das Problem besteht seit 16. August 2022????? Ja, und wenn Du es wagst, zuviel zu meckern, ignorieren sie Dich und Deine Beanstandung.
Eddie6411284 43 Posted August 24, 2024 Author Posted August 24, 2024 Herzlichen Glückwunsch zum zweijährigen Bestehen des Fehlers. Lasst Euch nur Zeit mit dem Fix, eilt ja nicht. Das Geld für das Feature habt Ihr ja bekommen. Ne Gegenleistung muss da ja nicht sein. 1
Teddyknuddel 136 Posted August 24, 2024 Posted August 24, 2024 1 hour ago, Eddie6411284 said: Herzlichen Glückwunsch zum zweijährigen Bestehen des Fehlers. Lasst Euch nur Zeit mit dem Fix, eilt ja nicht. Das Geld für das Feature habt Ihr ja bekommen. Ne Gegenleistung muss da ja nicht sein. Also jetzt übertreibst Du aber....... sind doch erst 2 Jahre und 6 Tage.....
Eddie6411284 43 Posted September 23, 2024 Author Posted September 23, 2024 Zwei Jahre und einen Monat ohne Fix. 1
Teddyknuddel 136 Posted September 23, 2024 Posted September 23, 2024 3 hours ago, Eddie6411284 said: Zwei Jahre und einen Monat ohne Fix. Vergiss es einfach - die wollen nicht. Haben das Thema abgehakt. Hol Dir ne Dreambox oder so. Dann kannste dort direkt die Aufnahmen auf dem PC rüberziehen und bearbeiten.
Eddie6411284 43 Posted December 16, 2024 Author Posted December 16, 2024 Zwei Jahre und 4 Monate ohne Fix. Ist das Unfähigkeit oder Absicht? Gerade wieder mit tvstreamrecord Sendungen aufgenommen. Das funktioniert einfach.
Teddyknuddel 136 Posted December 17, 2024 Posted December 17, 2024 20 hours ago, Eddie6411284 said: Ist das Unfähigkeit oder Absicht? Pure Absicht - Nörgler wie Du und ich sind unerwünscht.
Eddie6411284 43 Posted March 26, 2025 Author Posted March 26, 2025 Auch in der 4.8.11.0 funktioniert das weiterhin nicht.
mad-max 2 Posted March 27, 2025 Posted March 27, 2025 Sorry, aber für mich ist das nicht so ganz klar, warum bei euch die Aufnahmen nicht funktionieren. Für TV habe ich Emby an meinen DVBViewer Server angebunden. Die Aufnahmen, die ich in der Android App von Emby plane, laufen sauber durch und die Wiedergabe funktioniert ebenso ohne Probleme. Das ist so mit der aktuellen Emby Version, als auch mit den Vorgängerversionen so gewessen.
Eddie6411284 43 Posted March 29, 2025 Author Posted March 29, 2025 Das freut mich für Dich, dass Du keine Probleme hast. Hatte ich mit Emby 4.6 auch nicht. Ab der 4.7 funktioniert es leider bei mir nicht mehr. In der 4.7 wurden weitere Sachen kaputt optimiert, die man ganz plötzlich doch reparieren konnte. Wenigstens so halbwegs. Ich sage nur DLNA Renderer. Alles Weitere kannst Du dem Thread entnehmen. Gruß Eddie 1
Eddie6411284 43 Posted August 16, 2025 Author Posted August 16, 2025 Drei Jahre sind rum, immer noch kein Fix.
