damien_c2 7 Posted August 16, 2022 Posted August 16, 2022 Hello, for no reason emby app for firestick/lg keep buffering after investigation the only fix i have find is to reinstall the app and it fix the issue. What could cause the issue ?
ebr 16337 Posted August 16, 2022 Posted August 16, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
damien_c2 7 Posted August 17, 2022 Author Posted August 17, 2022 I have send the log by the emby app for firestick Playing: Any show or movie Time: 22:19 User: Ludovic
ebr 16337 Posted August 17, 2022 Posted August 17, 2022 10 hours ago, damien_c2 said: I have send the log by the emby app for firestick Playing: Any show or movie Time: 22:19 User: Ludovic Hi. There was no playback in that log. Please play an item for a few seconds until it exhibits the problem. Then send the log from the app and also provide the server log and any ffmpeg logs that are also created. Thanks.
damien_c2 7 Posted August 18, 2022 Author Posted August 18, 2022 I have send the log by the emby app for firestick Playing: Any show or movie Time: 17:54 User: faucher010 I have also add the log from the server embyserver.txt
ebr 16337 Posted August 18, 2022 Posted August 18, 2022 Lots of dropped frames and very slow network response. Is this a remote machine? Wireless?
damien_c2 7 Posted August 18, 2022 Author Posted August 18, 2022 Hello, you mean the server or the firestick ?
ebr 16337 Posted August 18, 2022 Posted August 18, 2022 1 hour ago, damien_c2 said: Hello, you mean the server or the firestick ? I guess both. Is the stick on a remote location from the server and is it using a wireless connection? I'm assuming the server is hardwired...
damien_c2 7 Posted August 18, 2022 Author Posted August 18, 2022 35 minutes ago, ebr said: I guess both. Is the stick on a remote location from the server and is it using a wireless connection? I'm assuming the server is hardwired... I have found the issue, it was my ISP. thx for the support ! 1
damien_c2 7 Posted August 19, 2022 Author Posted August 19, 2022 On 8/18/2022 at 8:26 AM, ebr said: Lots of dropped frames and very slow network response. Is this a remote machine? Wireless? Is there anyway i can see in the server log dropped frames ?
ebr 16337 Posted August 20, 2022 Posted August 20, 2022 16 hours ago, damien_c2 said: Is there anyway i can see in the server log dropped frames ? You could use the ADB to tail your log.
damien_c2 7 Posted August 21, 2022 Author Posted August 21, 2022 14 hours ago, ebr said: You could use the ADB to tail your log. Is it something to worry about: *** Error Report *** Version: 4.7.6.0 Command line: C:\Users\Administrateur\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.17763 Framework: .NET 6.0.7 OS/Process: x64/x64 Runtime: C:/Users/Administrateur/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Administrateur\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Administrateur\AppData\Roaming\Emby-Server\system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'name') at Emby.Server.Implementations.Library.UserManager.GetUserByName(ReadOnlySpan`1 name) at Emby.Server.Implementations.Session.SessionManager.AuthenticateNewSessionInternal(AuthenticationRequest request, Boolean enforcePassword, CancellationToken cancellationToken) at Emby.Api.UserService.Post(AuthenticateUserByName request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: MediaBrowser.Controller.Entities.User GetUserByName(System.ReadOnlySpan`1[System.Char])
Luke 42245 Posted August 21, 2022 Posted August 21, 2022 4 minutes ago, damien_c2 said: Is it something to worry about: *** Error Report *** Version: 4.7.6.0 Command line: C:\Users\Administrateur\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.17763 Framework: .NET 6.0.7 OS/Process: x64/x64 Runtime: C:/Users/Administrateur/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 10 Data path: C:\Users\Administrateur\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Administrateur\AppData\Roaming\Emby-Server\system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'name') at Emby.Server.Implementations.Library.UserManager.GetUserByName(ReadOnlySpan`1 name) at Emby.Server.Implementations.Session.SessionManager.AuthenticateNewSessionInternal(AuthenticationRequest request, Boolean enforcePassword, CancellationToken cancellationToken) at Emby.Api.UserService.Post(AuthenticateUserByName request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: MediaBrowser.Controller.Entities.User GetUserByName(System.ReadOnlySpan`1[System.Char]) Please attach the complete emby server log. Thanks.
damien_c2 7 Posted August 21, 2022 Author Posted August 21, 2022 15 hours ago, Luke said: Please attach the complete emby server log. Thanks. There you go friend. embyserver.txt
Luke 42245 Posted August 23, 2022 Posted August 23, 2022 On 8/21/2022 at 2:52 PM, damien_c2 said: There you go friend. embyserver.txt 29.42 MB · 0 downloads I would say nothing to worry about. @TeamB there's a lot of authentication in this log from EmbyCon and they appear to be missing the username to authenticate.
TeamB 2440 Posted August 23, 2022 Posted August 23, 2022 partially set up client or corrupt settings file I would guess. Cant reproduce with my test system.
TeamB 2440 Posted August 23, 2022 Posted August 23, 2022 I think I am able to reproduce this now, will look into it. 1
