MAX92 93 Posted August 15, 2022 Posted August 15, 2022 (edited) Bonjour, J'ai un léger problème avec les fichiers Dolby Vision, j'ai des couleurs qui ne ressemblent à rien Que ce soit sur la shield pro 2019, mon téléphone ou mes PC, toujours la même chose. SI vous voulez voir chez vous, voici un fichier exemple qui ne fonctionne pas du tout. ¦› 4K Dolby Vision video test | Food, Landscape, LG Earth, NASA (demolandia.net) : Prendre la vidéo Landscape Edited August 15, 2022 by MAX92
Luke 42239 Posted August 15, 2022 Posted August 15, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
ebr 16333 Posted August 15, 2022 Posted August 15, 2022 Hi. We need to see exactly how the item is playing in your environment. That is where the logs requested will help. If this is a DV item without a fallback HDR10 layer, though, and transcoding is needed, then I do not believe it will be possible to tone map the colors properly. @pwhodges
MAX92 93 Posted August 16, 2022 Author Posted August 16, 2022 This is the logembyserver.txtffmpeg-transcode-2ccd3b62-2cdc-4db0-95c9-c3ccc7031b01_1.txt
Solution ebr 16333 Posted August 16, 2022 Solution Posted August 16, 2022 Hi. Yes, that is DV profile 5 which we cannot currently tone map when transcoding.
MAX92 93 Posted August 16, 2022 Author Posted August 16, 2022 Many thanks @ebr Do you know a software which can ? Do you think it will be possible in the future ?
