chef 3811 Posted August 14, 2022 Posted August 14, 2022 Hi! Inside an IChannel, I am able to choose types of images available in the layout. If I set the images to backdrop and thumb, then this adds those options to the layout of the channel. On Android this means that, on the hone screen, thumbs and backdrops are used. Inside the webapp, I still experience primary images on the home screen. It seems that the dashboard prefers primary first, then uses other image types as a secondary option. The continue watching row will always use thumb images, or backdrops. Is the ability to control this in the IChannel? Thanks so much!
Luke 42237 Posted August 16, 2022 Posted August 16, 2022 HI, this is something that needs review, and possibly change, but in the meantime I would just have your channel supply the same image for both the primary and thumb types. 1
