Lost pin code in TraktTV extension
Hello,
It's been several weeks since I realized that the sync with trakt no longer works. In the home page of my server in the alerts I see a "Sync library to trakt.tv failed" When I go to the extensions at trakt.tv in the Authentication Pin dialog box, the PIN code previously filled in is now empty. If I redo a Get Pin and put the new one back on, it will work again directly because I launch the tasks by scheduled tasks but within 2-3 days the Pin code will disappear again. What can I do ?
Thank you
rodainas
That's how it works, it’s always cleared, the redo isn’t necessary unless there is another problem with the syncing.
