Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 1 minute ago, phoenixexcinere said: please don't bother unnecessarily. Seems to be a "special" problem. I like to be thorough and I create these plugins for all to enjoy. The fact that it didn't work on Linux or Windows now gives me great cause for concern. so i want to fix this once and for all. and it's not just you, there are others that are experiencing weird playback issues. 1
Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 @phoenixexcinere Can you do me a favor and just uninstall VP. Set up cinema intros and see if that is working well and as expected. This will help me troubeshoot. Cheers buddy
Guest phoenixexcinere Posted October 28, 2022 Posted October 28, 2022 5 minutes ago, Cheesegeezer said: Can you do me a favor and just uninstall VP. Set up cinema intros and see if that is working well and as expected. This will help me troubeshoot. sure, give me some minuts
Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 3 minutes ago, phoenixexcinere said: sure, give me some minuts no rush fella. I'm all coded out today. so just take your time
Guest phoenixexcinere Posted October 28, 2022 Posted October 28, 2022 No problem, I still had the server on anyway and nothing exciting is running on Twitch right now So with the Cinema Plugin it works right away
Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 17 minutes ago, phoenixexcinere said: No problem, I still had the server on anyway and nothing exciting is running on Twitch right now So with the Cinema Plugin it works right away Thanks…. i got work to do!! tomorrow enjoying whisky right now lol
Bumsen 0 Posted October 28, 2022 Posted October 28, 2022 have the same error, can see that during the libary scan it does not find anything with vantage points. have installed new libary with a few video files (mp4), no new files are found either in new or old folders. i run emby on synology nas dsm7.1 embyserver (2).txt
Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 3 minutes ago, Bumsen said: have the same error, can see that during the libary scan it does not find anything with vantage points. have installed new libary with a few video files (mp4), no new files are found either in new or old folders. i run emby on synology nas dsm7.1 embyserver (2).txt 1.39 MB · 0 downloads Thanks for the info… im gonna look at this intensely and figure out why sh1t is not verking. 1
FoXiT 1 Posted October 30, 2022 Posted October 30, 2022 Good morning. Thank you for your work. I wanted to answer what I read previous, I specify that I am under embu beta 4.0.8.15, your plugin works perfectly well, I have the launch of intros, certifications and tags, on integrality From the library. Here is the adjustment I made, if it can help. Asustor AS6102 NAS material.
FoXiT 1 Posted October 30, 2022 Posted October 30, 2022 Good morning. Thank you for your work. I wanted to answer what I read earlier, I specify that I am under embu beta 4.0.8.15, your plugin works perfectly well, I have the launch of intros, certifications and tags, on the entire library. Here is the adjustment I made, if it can help. Asustor AS6102 NAS material. 1
Cheesegeezer 3106 Posted November 3, 2022 Author Posted November 3, 2022 (edited) Yo peeps, i just fixed a bug in Media Toolbox Plugin and wondering if you have Path substitution as well as direct paths in your libraries. I had to set EnablePathSubstitution to true for that. So, i'll look into this tomorrow if that is the case. I can't see how because they are direct paths but it may be a limitation of the library your trying to play from. I dunno!! i'm trying to hit a barn door with a shotgun at the moment LOL!! i think it's this setting when setting up a library Edited November 3, 2022 by Cheesegeezer
crusher11 1146 Posted November 9, 2022 Posted November 9, 2022 There doesn't seem to be a way to toggle "enable for watched" on codec/tag intros?
unisoft 355 Posted November 19, 2022 Posted November 19, 2022 On 30/10/2022 at 03:57, FoXiT said: Good morning. Thank you for your work. I wanted to answer what I read earlier, I specify that I am under embu beta 4.0.8.15, your plugin works perfectly well, I have the launch of intros, certifications and tags, on the entire library. Here is the adjustment I made, if it can help. Asustor AS6102 NAS material. What about TV Intros, usign up to 3 different intros, and only using TAG Match to start each named video intro? Cinema Intros worked for me, but TV Intros are borked and only work on the Emby LG App and only for one intro file to a matching tagname.
Cheesegeezer 3106 Posted November 19, 2022 Author Posted November 19, 2022 2 hours ago, unisoft said: What about TV Intros, usign up to 3 different intros, and only using TAG Match to start each named video intro? Cinema Intros worked for me, but TV Intros are borked and only work on the Emby LG App and only for one intro file to a matching tagname. I’m gonna have to post my code in the dev section and see if Luke or Eric can spot my shortfall for TV. Im back working on Iridium at the mo when i get a moment. I’ll give it a couple of hours later to see if i can fix this again. i have to admit defeat at that point. 1
Cheesegeezer 3106 Posted November 21, 2022 Author Posted November 21, 2022 On 19/11/2022 at 12:34, unisoft said: What about TV Intros, usign up to 3 different intros, and only using TAG Match to start each named video intro? Cinema Intros worked for me, but TV Intros are borked and only work on the Emby LG App and only for one intro file to a matching tagname. Luke has confirmed there are some issues with Intros for TV Episodes currently 15 hours ago, Luke said: There is an issue right now with episode intros where they're only getting played on the first episode of the series. 1
crusher11 1146 Posted November 23, 2022 Posted November 23, 2022 On 11/9/2022 at 12:00 PM, crusher11 said: There doesn't seem to be a way to toggle "enable for watched" on codec/tag intros? @Cheesegeezer? I managed to go into the XML file and toggle it manually, but the UI doesn't seem to support it.
Cheesegeezer 3106 Posted November 28, 2022 Author Posted November 28, 2022 On 23/11/2022 at 06:31, crusher11 said: @Cheesegeezer? I managed to go into the XML file and toggle it manually, but the UI doesn't seem to support it. Sorry chief, I’ll take a look. Is this for tv or for movies
crusher11 1146 Posted November 28, 2022 Posted November 28, 2022 I've only used it for movies, no idea if it also affects TV. 1
Cheesegeezer 3106 Posted November 30, 2022 Author Posted November 30, 2022 On 28/11/2022 at 20:48, crusher11 said: I've only used it for movies, no idea if it also affects TV. I can't reproduce the fault, what is it that you are trying to do exactly. Is this for just tags? or what, can you share a screenshot of the GUI before you hit save. I can try to reproduce this is one i just added for
crusher11 1146 Posted December 5, 2022 Posted December 5, 2022 Okay so it's at least partly/mostly a PEBKAC error, partly a potential UI issue. I overlooked the toggle on that one because it's lumped in with all the other toggles. Maybe separate it a little?
Cheesegeezer 3106 Posted December 5, 2022 Author Posted December 5, 2022 5 hours ago, crusher11 said: Okay so it's at least partly/mostly a PEBKAC error, partly a potential UI issue. I overlooked the toggle on that one because it's lumped in with all the other toggles. Maybe separate it a little? Every toggle has a title and description. I can’t cater for people not reading the options. I’m dyslexic and the layout looks fine to me.
pringhouse 2 Posted December 15, 2022 Posted December 15, 2022 (edited) Having problems playing intros / trailers - the error I receive is: 2022-12-14 15:12:39.303 Error App: Error getting intros *** Error Report *** Version: 4.8.0.21 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.19.14-Unraid (root@Develop) (gcc (GCC) 12.2.0, GNU ld version 2.39-slack151) #1 SMP PREEMPT_DYNAMIC Thu Oct 6 09:15:00 PDT 2022 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.MissingMethodException: System.MissingMethodException: Method not found: 'Void MediaBrowser.Controller.Entities.InternalItemsQuery.set_ExcludeOwnerIds(Int64[])'.c at VPCode.VantagePoint.VPIntroProvider.GetInternalTrailers(BaseItem item, User user, VPItem vpItem) at VPCode.VantagePoint.VPIntroProvider.GetResultForMovies(BaseItem item, User user, PluginConfiguration config) at VPCode.VantagePoint.VPIntroProvider.GetIntros(BaseItem item, User user) at Emby.Server.Implementations.Library.LibraryManager.GetIntros(IIntroProvider provider, BaseItem item, User user) Source: VantagePoint TargetSite: System.Collections.Generic.List`1[MediaBrowser.Controller.Library.IntroInfo] GetInternalTrailers(MediaBrowser.Controller.Entities.BaseItem, MediaBrowser.Controller.Entities.User, VPCode.VantagePoint.Configuration.VPItem) Docker through Unraid - Emby Version - Version 4.8.0.21 beta - Vantagepoint Version - 2.1.0.2 Edited December 15, 2022 by pringhouse
Cheesegeezer 3106 Posted December 15, 2022 Author Posted December 15, 2022 8 minutes ago, pringhouse said: Having problems playing intros / trailers - the error I receive is: 2022-12-14 15:12:39.303 Error App: Error getting intros *** Error Report *** Version: 4.8.0.21 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.19.14-Unraid (root@Develop) (gcc (GCC) 12.2.0, GNU ld version 2.39-slack151) #1 SMP PREEMPT_DYNAMIC Thu Oct 6 09:15:00 PDT 2022 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.MissingMethodException: System.MissingMethodException: Method not found: 'Void MediaBrowser.Controller.Entities.InternalItemsQuery.set_ExcludeOwnerIds(Int64[])'.c at VPCode.VantagePoint.VPIntroProvider.GetInternalTrailers(BaseItem item, User user, VPItem vpItem) at VPCode.VantagePoint.VPIntroProvider.GetResultForMovies(BaseItem item, User user, PluginConfiguration config) at VPCode.VantagePoint.VPIntroProvider.GetIntros(BaseItem item, User user) at Emby.Server.Implementations.Library.LibraryManager.GetIntros(IIntroProvider provider, BaseItem item, User user) Source: VantagePoint TargetSite: System.Collections.Generic.List`1[MediaBrowser.Controller.Library.IntroInfo] GetInternalTrailers(MediaBrowser.Controller.Entities.BaseItem, MediaBrowser.Controller.Entities.User, VPCode.VantagePoint.Configuration.VPItem) Docker through Unraid - Emby Version - Version 4.8.0.21 beta - Vantagepoint Version - 2.1.0.2 Let me see if i need to update the nugets... i forgot to do this one. Standby...
Cheesegeezer 3106 Posted December 15, 2022 Author Posted December 15, 2022 Updated to 2.1.0.4 See if that helps. if not i'll try to track it down. Might be the beta version that's broken it again.
pringhouse 2 Posted December 15, 2022 Posted December 15, 2022 2.1.0.4 - 2022-12-14 19:58:26.242 Info Vantage Point: Getting Intro Results for Movies - Movie Name = Bad Boys 2022-12-14 19:58:26.246 Error App: Error getting intros *** Error Report *** Version: 4.8.0.21 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.19.14-Unraid (root@Develop) (gcc (GCC) 12.2.0, GNU ld version 2.39-slack151) #1 SMP PREEMPT_DYNAMIC Thu Oct 6 09:15:00 PDT 2022 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /system System.MissingMethodException: System.MissingMethodException: Method not found: 'Void MediaBrowser.Controller.Entities.InternalItemsQuery.set_ExcludeOwnerIds(Int64[])'. at VPCode.VantagePoint.VPIntroProvider.GetInternalTrailers(BaseItem item, User user, VPItem vpItem) at VPCode.VantagePoint.VPIntroProvider.GetResultForMovies(BaseItem item, User user, PluginConfiguration config) at VPCode.VantagePoint.VPIntroProvider.GetIntros(BaseItem item, User user) at Emby.Server.Implementations.Library.LibraryManager.GetIntros(IIntroProvider provider, BaseItem item, User user) Source: VantagePoint TargetSite: System.Collections.Generic.List`1[MediaBrowser.Controller.Library.IntroInfo] GetInternalTrailers(MediaBrowser.Controller.Entities.BaseItem, MediaBrowser.Controller.Entities.User, VPCode.VantagePoint.Configuration.VPItem)
