Cheesegeezer 3106 Posted October 23, 2022 Author Posted October 23, 2022 (edited) 55 minutes ago, Spaceboy said: here you go. just one specific intro should play before all episodes and movies embyserver(22).txt 257.22 kB · 1 download Is cinemaIntros enable for the client? I think that needs to be on IIRC, but I can’t remember and not able to check just now Edited October 23, 2022 by Cheesegeezer
Spaceboy 2573 Posted October 23, 2022 Posted October 23, 2022 2 minutes ago, Cheesegeezer said: Is cinemaIntros enable for the client? I think that needs to be on IIRC, but I can’t remember and not able to check just now yep
Guest phoenixexcinere Posted October 26, 2022 Posted October 26, 2022 On 10/22/2022 at 12:18 PM, Cheesegeezer said: Hi there, apologies for missing this. Thanks for your answer and I understand, but it does not work. Today I tested a bit, my intros don't play, none of them. That's why I downloaded an Emby Intro from the forum here and it works without any problems. Could it be that there is a problem with some codes or formats? I just don't see much of a difference between the two videos. Attached is a picture with information about the codecs of the two intro videos
Cheesegeezer 3106 Posted October 26, 2022 Author Posted October 26, 2022 4 minutes ago, phoenixexcinere said: Thanks for your answer and I understand, but it does not work. Today I tested a bit, my intros don't play, none of them. That's why I downloaded an Emby Intro from the forum here and it works without any problems. Could it be that there is a problem with some codes or formats? I just don't see much of a difference between the two videos. Attached is a picture with information about the codecs of the two intro videos I am completely baffled. The plugin has no bearing on the type of media as long as it is of Type Video (which could be mp4, xvid, divx, mkv) The plugin simply collects a list of paths to the video files and plays them accordinng to the users set up. Have you run a library scan since adding that file. The one on the left is the emby intro i made. but can't understand why it wont plaay the one on the right. Can you post the intro1.mp4 here please as a zip and i will download and try on my system. I'm running Beta 4.8.0.13 nowon my dev laptop and did tests on my stable 4.7.8 main server and both work fine for me. This is really frustrating, but i would love to get to the bottom of this once and for all.
Guest phoenixexcinere Posted October 26, 2022 Posted October 26, 2022 (edited) I was surprised myself, but that's the only difference, at least for me. Otherwise everything is identical. The permissions are the same, the directory is the same. What confuses me, however, is that my certification bumpers also work, they have the same codec as the intros. But there must be a reason why one video works and the other doesn't but if I convert the video that works with Handbrake, it no longer works either. Kinda very strange Edited October 26, 2022 by phoenixexcinere
Cheesegeezer 3106 Posted October 26, 2022 Author Posted October 26, 2022 11 minutes ago, phoenixexcinere said: I was surprised myself, but that's the only difference, at least for me. Otherwise everything is identical. The permissions are the same, the directory is the same. What confuses me, however, is that my certification bumpers also work, they have the same codec as the intros. But there must be a reason why one video works and the other doesn't my thoughts exactly 11 minutes ago, phoenixexcinere said: but if I convert the video that works with Handbrake, it no longer works either. Kinda very strange Wooooooah that’s crazy mental. Is there some setting in handbrake that locks the file. try this. Create a mixed library and add your intros folder to it. See how emby handles playback of those intros. its about all i can suggest at the mo
Guest phoenixexcinere Posted October 26, 2022 Posted October 26, 2022 with mixed its still the same I once created multiple intros with two intros. One intro that works and one intro that doesn't work. Even in the log file I don't see a problem that could explain it The intro "Emby_Intro_AACv2_5_1.mp4" is played in the log file and "björnflix_Mountain Peaks Opener_1080p.mp4" will not play. logfile.txt
unisoft 355 Posted October 26, 2022 Posted October 26, 2022 Vantage Point movies works for me, bumpers, BBCFC classification on all clients I've used which is nearly all. Vantage Point TV does not work on any client except the LG TV Emby app, but it did used to work on older server version 4.6.7 and clients until Emby team updated them.
Cheesegeezer 3106 Posted October 26, 2022 Author Posted October 26, 2022 29 minutes ago, phoenixexcinere said: with mixed its still the same so the issue is with the media file. Is the mediainfo correct in the details page? can you share a non playable intro file for me please i really would love to know or figure out… why? 29 minutes ago, phoenixexcinere said: I once created multiple intros with two intros. One intro that works and one intro that doesn't work. Even in the log file I don't see a problem that could explain it The intro "Emby_Intro_AACv2_5_1.mp4" is played in the log file and "björnflix_Mountain Peaks Opener_1080p.mp4" will not play. logfile.txt 36.92 kB · 0 downloads
Guest phoenixexcinere Posted October 26, 2022 Posted October 26, 2022 24 minutes ago, Cheesegeezer said: can you share a non playable intro file for me please i really would love to know or figure out… why? Of course, that's an intro that doesn't work for me. It would be really crazy if it worked for you, because then I really don't know what to do anymore björnflix_Mountain Peaks Opener_1080p.mp4
Cheesegeezer 3106 Posted October 26, 2022 Author Posted October 26, 2022 14 minutes ago, phoenixexcinere said: Of course, that's an intro that doesn't work for me. It would be really crazy if it worked for you, because then I really don't know what to do anymore björnflix_Mountain Peaks Opener_1080p.mp4 Can you zip/rar/7zip it please. Cant download videos direct from the forum. Cheers Ta
Guest phoenixexcinere Posted October 27, 2022 Posted October 27, 2022 21 hours ago, Cheesegeezer said: Can you zip/rar/7zip it please. Cant download videos direct from the forum. Cheers Ta yes of course Sir björnflix_Mountain Peaks Opener_1080p.mp4.tar.gz
Cheesegeezer 3106 Posted October 27, 2022 Author Posted October 27, 2022 5 minutes ago, phoenixexcinere said: yes of course Sir björnflix_Mountain Peaks Opener_1080p.mp4.tar.gz 15.73 MB · 0 downloads Testing now. I'm wondering if the name is tooooo long or it doesn't like the umlouts over the O
Guest phoenixexcinere Posted October 27, 2022 Posted October 27, 2022 yes the filenames are very long but I tested it with the name "intro1" "intro2" and so on, with the same result.
Cheesegeezer 3106 Posted October 27, 2022 Author Posted October 27, 2022 9 minutes ago, phoenixexcinere said: yes the filenames are very long but I tested it with the name "intro1" "intro2" and so on, with the same result. So here is my set up lets see
Cheesegeezer 3106 Posted October 27, 2022 Author Posted October 27, 2022 It didn't play for me either But Vantage Point does find it and add it to the play list. Oh shoot i forgot to library scan..... 2 secs
Cheesegeezer 3106 Posted October 27, 2022 Author Posted October 27, 2022 So library scan picks up the intro lets see now!!! hehehehe
Guest phoenixexcinere Posted October 27, 2022 Posted October 27, 2022 hmm strange. I have no idea why it doesn't work here. could it possibly be a codec problem with my PC? First I set up Vantage Point with a Windows PC, now Mint is running here and some codecs don't like it that much. but actually the PC has nothing to do with it.
Cheesegeezer 3106 Posted October 27, 2022 Author Posted October 27, 2022 8 minutes ago, phoenixexcinere said: hmm strange. I have no idea why it doesn't work here. could it possibly be a codec problem with my PC? First I set up Vantage Point with a Windows PC, now Mint is running here and some codecs don't like it that much. but actually the PC has nothing to do with it. I don't know what Mint is. I'm on Win 10 no codec packs or anything installed
Guest phoenixexcinere Posted October 27, 2022 Posted October 27, 2022 4 minutes ago, Cheesegeezer said: I don't know what Mint is. Linux Mint, it based on ubuntu. I will try tomorrow from work, there I have a windows notebook.
Cheesegeezer 3106 Posted October 27, 2022 Author Posted October 27, 2022 3 minutes ago, phoenixexcinere said: Linux Mint, it based on ubuntu. I will try tomorrow from work, there I have a windows notebook. Dang... maybe it's something to do with that. I'll speak with the core team and see if there is anything i can do to irradicate this issue on my side. But the red flags started singing to me when you couldn't even play those intros when you created a mixed library of them. Good luck fella and let me know the outcome of your tests please.
Guest phoenixexcinere Posted October 28, 2022 Posted October 28, 2022 Sooo, I did a little more testing today: I configured Vantage Point from work (Windows PC), I completely wiped and recreated the movie library, I uninstalled and reinstalled Vantage Point, I tried again with mixed content, unfortunately all to no avail. He just plays the Emby intro and the FSK bumpers but not my intros. I have absolutely no idea what it could be. Especially since it has worked before. During the closed beta it ran without any problems. I then disabled Vantage Point for a while and now it doesn't work anymore. Very mysterious. But hey, I can live without it for a while. Maybe reinstalling the Emby container will help, I'll have to test that when I get a chance. Translated with Google, but I hope you understand anyway
Cheesegeezer 3106 Posted October 28, 2022 Author Posted October 28, 2022 6 minutes ago, phoenixexcinere said: Sooo, I did a little more testing today: I configured Vantage Point from work (Windows PC), I completely wiped and recreated the movie library, I uninstalled and reinstalled Vantage Point, I tried again with mixed content, unfortunately all to no avail. He just plays the Emby intro and the FSK bumpers but not my intros. I have absolutely no idea what it could be. Especially since it has worked before. During the closed beta it ran without any problems. I then disabled Vantage Point for a while and now it doesn't work anymore. Very mysterious. But hey, I can live without it for a while. Maybe reinstalling the Emby container will help, I'll have to test that when I get a chance. Translated with Google, but I hope you understand anyway Clear as Day my friend. So from a fresh install nothing works. I will try this myself tomorrow. and see if there are some legacy issues since the cores updates that may be hiding in the background. I really want you guys to enjoy this and i don't like why it's not working for you all. 2
Guest phoenixexcinere Posted October 28, 2022 Posted October 28, 2022 please don't bother unnecessarily. Seems to be a "special" problem.
