Cheesegeezer 3106 Posted August 14, 2022 Author Posted August 14, 2022 Can you mediaInfo panels at the bottom of the details page for atomic blonde just to see what the actual embedded title is rather than what emby is displaying. ta
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 (edited) 15 hours ago, crusher11 said: Quick question are you running beta or release? After adding intros or renaming are you running Library Scan if on Beta 4.8.0.7 there is incompatibility with 4.7.6.0 I found a cheeky bug for the Title matches which adds whitespace and have dealt with this. I also made a switch to match Track titles now (just for some piece and quiet) - matched strings are now removed - you will need to redo that codec intro you have already done. TV Episodes Tab is now enabled and can be used for TV episode intros. Look out in the catalogue for v2.1.0.1 Edited August 15, 2022 by Cheesegeezer
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 V2.1.0.1 RELEASED Adds functionality for TV Shows Changes "Rated R" rating to just "R" custom Strings for matching embedded Track Titles is now removed. If you are using these you will need to delete and create a new intro based on next point #4 Match Embedded Track Title switch has been added. Minor Bug Fixes
crusher11 1145 Posted August 15, 2022 Posted August 15, 2022 2 hours ago, Cheesegeezer said: if on Beta 4.8.0.7 there is incompatibility with 4.7.6.0 Huh?
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 8 minutes ago, crusher11 said: Huh? if you are running 4.8.0.7 Beta Server, the plugin will not work because it doesn't refresh new intros
crusher11 1145 Posted August 15, 2022 Posted August 15, 2022 But what does 4.7.6.0 have to do with it? I'm running 4.8.0.5 at the moment.
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 I don't think it's worth trying to explain things to you. when you do a library scan, can you check your logs to see you can see this in it
crusher11 1145 Posted August 15, 2022 Posted August 15, 2022 1 hour ago, Cheesegeezer said: I don't think it's worth trying to explain things to you. when you do a library scan, can you check your logs to see you can see this in it Nope, there's none of that in my logs.
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 8 minutes ago, crusher11 said: Nope, there's none of that in my logs. that's good! The library scan issues for detecting intros is introduced in 4.8.0.7 when i am building the plugin using a 4.7.6.0 nuget. It's okay... you don't have to understand what that means. But i have to build for stable release and hope that betas work, if not then i know which version it doesn't and then clarify with users.
crusher11 1145 Posted August 15, 2022 Posted August 15, 2022 Seems like it's okay up to 4.8.0.5 then. Unless it breaks when I update the plugin. We shall see.
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 1 minute ago, crusher11 said: Seems like it's okay up to 4.8.0.5 then. Unless it breaks when I update the plugin. We shall see. Should be good give it a whirl. do a library scan before running plugin just to ensure all intros have been picked up and added
crusher11 1145 Posted August 15, 2022 Posted August 15, 2022 10 minutes ago, Cheesegeezer said: Should be good give it a whirl. do a library scan before running plugin just to ensure all intros have been picked up and added Well now it's not playing any intros at all... embyserver.txt
unisoft 355 Posted August 15, 2022 Posted August 15, 2022 (edited) BUG: VP Episodes release 2.1.0.1 doesn't save the minimum time under VP GLOBAL for episodes. Tried to change to 10 minutes by using up and down arrows and also by entering time. Also changed the Movie minimum time to see if it would save both values. Looked at VantagePoint.xml, and could only see a value for movie setting. On current version Emby Server 4.7.6.0 not a beta release. Also, some rewording from "MOVIES" to "TV SHOWS" where that minimum time is set on the VP GLOBAL tab. Original on screen text: "For example if you want intros to play for TV Shows that are longer than 45mins - enter 45 - this will only enable Vantage Point on Movies that are longer than 45 mins Anything below 45mins will ignore all intros and play as normal" So far though, good work, be nice to amend a configured item in the future too Edited August 15, 2022 by unisoft 1
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 2 hours ago, crusher11 said: Well now it's not playing any intros at all... embyserver.txt 32.89 MB · 0 downloads Why have you sent me an IntroSkip plugin log?
crusher11 1145 Posted August 15, 2022 Posted August 15, 2022 3 hours ago, Cheesegeezer said: Why have you sent me an IntroSkip plugin log? ...what?
Cheesegeezer 3106 Posted August 15, 2022 Author Posted August 15, 2022 5 minutes ago, crusher11 said: ...what? Dude take a look at it! It 32mb of IntroSkip log. This is VP2 issues
crusher11 1145 Posted August 16, 2022 Posted August 16, 2022 7 hours ago, Cheesegeezer said: Dude take a look at it! It 32mb of IntroSkip log. This is VP2 issues It's an Emby Server log. It's not a log for any specific plugin.
Cheesegeezer 3106 Posted August 16, 2022 Author Posted August 16, 2022 (edited) 5 hours ago, crusher11 said: It's an Emby Server log. It's not a log for any specific plugin. I know what the issues are (probably had episodes disabled). They have been fixed but there is a oddity for US ratings where Rated R is throwing some interesting results. I will push the fix shortly when i have the last bug fixed a good tip for submitting logs. is to rotate the log before doing an action it makes it much easier to read for the dev. unless there are start up issues, then that info needs to be there. Edited August 16, 2022 by Cheesegeezer
crusher11 1145 Posted August 16, 2022 Posted August 16, 2022 I rebooted the server to install the update, then made the changes required by the new Track Title system, and tried playing a movie. Rotating the log file wouldn't really have made any difference.
Cheesegeezer 3106 Posted August 16, 2022 Author Posted August 16, 2022 9 minutes ago, crusher11 said: Rotating the log file wouldn't really have made any difference. it makes it easy for me to look at, especially on a phone.
Cheesegeezer 3106 Posted August 17, 2022 Author Posted August 17, 2022 (edited) 11 hours ago, crusher11 said: I rebooted the server to install the update, then made the changes required by the new Track Title system, and tried playing a movie. Rotating the log file wouldn't really have made any difference. Try latest catalogue release. It should be bloody brilliant Edited August 17, 2022 by Cheesegeezer 1
gihayes 47 Posted August 17, 2022 Posted August 17, 2022 2 minutes ago, Cheesegeezer said: Try latest catalogue release. It should be bloody brilliant 1
Cheesegeezer 3106 Posted August 17, 2022 Author Posted August 17, 2022 14 minutes ago, gihayes said: It’s ok I’m waiting for crusher to live upto his handle. Crush my spirit 2
crusher11 1145 Posted August 17, 2022 Posted August 17, 2022 Back to where we were before. Bumper and trailers play as applicable, no track title matching. embyserver.txt
