r0gu3ptm 2 Posted July 15, 2025 Posted July 15, 2025 8 hours ago, Brojbeanu said: You când read 2 posts upside? What's the point in reading if nobody answers ?
Brojbeanu 5 Posted July 15, 2025 Posted July 15, 2025 Actually your question should have been: what's the point of writing if no one responds?
Brojbeanu 5 Posted July 15, 2025 Posted July 15, 2025 In fact you când use Cinema intros with your own movie and uninstall Vantage Point.
Luke 42150 Posted July 15, 2025 Posted July 15, 2025 1 hour ago, r0gu3ptm said: What's the point in reading if nobody answers ? Right, is there something you're trying to do with Vantage point that the core Cinema Intros feature can't do for you?
Brojbeanu 5 Posted July 15, 2025 Posted July 15, 2025 Although the question is not addressed to me, I could answer it myself: 1 in Cinema intros you cannot choose the file but only the folder and as such if there are multiple files in the folder they will all be played....
r0gu3ptm 2 Posted July 16, 2025 Posted July 16, 2025 14 hours ago, Luke said: Right, is there something you're trying to do with Vantage point that the core Cinema Intros feature can't do for you? Yup, the certifications bit Although the Cinema Intro plugin works just fine, Vantage Point has a bit more options: like certifications. And Brojbeanu is wrong: in Cinema Intro plugin you can choose how many intros to play from a folder with multiple items. Used to use it before I switched to Vantage Point. Maybe you guys can insert some settings in Cinema intro for certifications intros.
Brojbeanu 5 Posted July 16, 2025 Posted July 16, 2025 10 minutes ago, r0gu3ptm said: Yup, the certifications bit Although the Cinema Intro plugin works just fine, Vantage Point has a bit more options: like certifications. And Brojbeanu is wrong: in Cinema Intro plugin you can choose how many intros to play from a folder with multiple items. Used to use it before I switched to Vantage Point. Maybe you guys can insert some settings in Cinema intro for certifications intros. You totally misunderstood....I wasn't referring to the number of videos...but to which specific video. More to your point: you can't choose to play just one video and have it be video no. 3 (let's say)
r0gu3ptm 2 Posted July 16, 2025 Posted July 16, 2025 8 hours ago, Brojbeanu said: You totally misunderstood....I wasn't referring to the number of videos...but to which specific video. More to your point: you can't choose to play just one video and have it be video no. 3 (let's say) No, I can't but I can just leave one intro in the folder, so Cinema Intro will play only that. There is always a workaround.
amateurgod 33 Posted July 28, 2025 Posted July 28, 2025 Is anyone having issues with certification, for some reason it's always showing the not rated cert even though the film shows an age rating in Emby
StuBailey 35 Posted August 21, 2025 Posted August 21, 2025 I'm curious why Vantage Point seems to be bypassed when you use MOVIES display and click the play-button that plays consecutive movies.
StuBailey 35 Posted August 22, 2025 Posted August 22, 2025 opps, works on web.. Roku no. Wrong place to post. No need get whiny (inside joke)
Terramaris 1 Posted December 9, 2025 Posted December 9, 2025 I am trying to create a Codec/Tag intro for episodes. I have a video folder path, I set it for already watched episodes, and to play when a tag I set on the series matches the file name. For some reason though I cannot click save and I do not know why. I can set things up for movies, and I can even set up certifications for episodes, but I cannot have VP use tags for episodes!
