ecrispy 38 Posted August 13, 2022 Posted August 13, 2022 I use Emby on AndroidTv and think following can be improved. I think this may be common across clients? say you select Movies->movie1->actor->movie2 etc. You are now deep in a hierarchy and on screen you don't see the top level menu, so the only way to pick something else is to hit back multiple times. In contrast eg in Plex the left hand top level menu is always accessible. It would be nice if there was a quicker way.
arrbee99 1836 Posted August 13, 2022 Posted August 13, 2022 Think on a Shield you long press the Back (<) key and it goes to top of the Home page. Something similar on Fire TVs. Can't check to make sure at the moment and thats for the AndroidTV Emby app. 3
FrostByte 5454 Posted August 13, 2022 Posted August 13, 2022 (edited) Correct, here are some others: long press BACK ◁ from anywhere to return to the ATV home screen single press BACK ◁ to jump to the beginning of a list long press SELECT to toggle SFN during playback Edited August 13, 2022 by FrostByte 2 1
ebr 16337 Posted August 13, 2022 Posted August 13, 2022 13 hours ago, FrostByte said: long press SELECT to toggle SFN That's during playback. In most other situations, a long-press of OK is going to produce a context menu. 1
ebr 16337 Posted August 14, 2022 Posted August 14, 2022 21 minutes ago, justinrh said: What is SFN? Stats For Nerds 1
