iiiJoe 62 Posted August 11, 2022 Posted August 11, 2022 Hello to all! I'm just wondering if hardware detection should be happening so often. It occurred 22 times in a 12 hr period. I've attached a couple of the logs from that period. Any help would be much appreciated. hardware_detection-63795805788.txt hardware_detection-63795796933.txt hardware_detection-63795796604.txt hardware_detection-63795762519.txt hardware_detection-63795762527.txt
Luke 42186 Posted August 11, 2022 Posted August 11, 2022 Hi, are you experiencing a problem? It will run anytime the system reports a display change, that's for one.
iiiJoe 62 Posted August 11, 2022 Author Posted August 11, 2022 Well, I am having playback issues in live tv as well as failed recording issues with this error in the logs: HTTP error 404 Not Found
Luke 42186 Posted August 11, 2022 Posted August 11, 2022 38 minutes ago, iii2405 said: Well, I am having playback issues in live tv as well as failed recording issues with this error in the logs: HTTP error 404 Not Found Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
visproduction 328 Posted August 11, 2022 Posted August 11, 2022 In your Hardware detection log, there are several errors for device: "DeviceInfo": { "Description": "Microsoft Basic Render Driver", "DirectXType": "DX11_1", "DeviceId": 140, "VendorId": 5140, "SubSysId": 0, "AdapterLuidHigh": 0, "AdapterLuidLow": 29512, "DedicatedSystemMemory": 0, "DedicatedVideoMemory": 0, "SharedSystemMemory": 2082562048 Error initializing an MFX session: MFX_ERR_UNSUPPORTED Initialize MFX session: API version is 1.35, implementation version is 1.19 AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_HIGH10 AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_CONSTRAINED_BASELIN AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_CONSTRAINED_HIGH AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_PROGRESSIVE_HIGH AddDecoders - Codec not supported: hevc, vp8, vp9 AddEncoders - Codec not supported. Out codec id: mpeg2video and many more That's enough errors, that I would suspect a reinstall might be a good idea. Try turning hardware acceleration off.
Happy2Play 9800 Posted August 12, 2022 Posted August 12, 2022 4 hours ago, visproduction said: In your Hardware detection log, there are several errors for device: "DeviceInfo": { "Description": "Microsoft Basic Render Driver", "DirectXType": "DX11_1", "DeviceId": 140, "VendorId": 5140, "SubSysId": 0, "AdapterLuidHigh": 0, "AdapterLuidLow": 29512, "DedicatedSystemMemory": 0, "DedicatedVideoMemory": 0, "SharedSystemMemory": 2082562048 Error initializing an MFX session: MFX_ERR_UNSUPPORTED Initialize MFX session: API version is 1.35, implementation version is 1.19 AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_HIGH10 AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_CONSTRAINED_BASELIN AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_CONSTRAINED_HIGH AddDecoderProfiles - Profile not supported (1): MFX_PROFILE_AVC_PROGRESSIVE_HIGH AddDecoders - Codec not supported: hevc, vp8, vp9 AddEncoders - Codec not supported. Out codec id: mpeg2video and many more That's enough errors, that I would suspect a reinstall might be a good idea. Try turning hardware acceleration off. All my HW logs have this (multiple machines) except this is different Initialize MFX session: API version is 1.35, implementation version is 1.19 as mine have 1.35 for both.
