Luke 42241 Posted August 11, 2022 Posted August 11, 2022 Hi there, why do you think this? Can you please explain in more detail? Thanks.
Waldoo 14 Posted August 11, 2022 Author Posted August 11, 2022 (edited) turning off remember me will take you to the login screen when you back out the app or done watching. this is not happening or am i mis understanding the feature. Edited August 11, 2022 by Waldoo
SamES 1084 Posted August 22, 2022 Posted August 22, 2022 (edited) When you turned off 'Remember Me', did you take note of the message that said 'This change will take effect the next time the app restarts'? Be aware that returning to the Home screen does not restart the app, you need to terminate and reload the app for this change to be effective. To terminate the app, double click the Home/TV button on the remote control. This should bring up the app switcher. Scroll to bring the Emby app to the front, then swipe up to terminate the app. Press the Menu button to return to the Menu. After terminating the app, reload it and now it should not remember the user. Of course, the other way to terminate the app is to restart the AppleTV device. Edited August 22, 2022 by SamES
Waldoo 14 Posted August 22, 2022 Author Posted August 22, 2022 99% sure I did that and it still remembers me
SamES 1084 Posted August 22, 2022 Posted August 22, 2022 8 minutes ago, Waldoo said: 99% sure I did that and it still remembers me Please check and confirm. Also try restarting the device after turning off Remember Me and see if that resolves it.
Waldoo 14 Posted August 22, 2022 Author Posted August 22, 2022 (edited) It also does not remember my server after typing it in. It’s lost on app restart trying it now Edited August 22, 2022 by Waldoo
Waldoo 14 Posted August 22, 2022 Author Posted August 22, 2022 I have remember me off and going to restart now
Waldoo 14 Posted August 22, 2022 Author Posted August 22, 2022 (edited) So I have to close the app each time? I was wishing it was automatic Edited August 22, 2022 by Waldoo
Luke 42241 Posted August 22, 2022 Posted August 22, 2022 For now yes but we'll look at improving it. Thanks.
Waldoo 14 Posted August 22, 2022 Author Posted August 22, 2022 problem is i have to retype the server each time
SamES 1084 Posted August 22, 2022 Posted August 22, 2022 1 hour ago, Waldoo said: problem is i have to retype the server each time Is it just after an update, or every time you restart the app? Have you always had to do that, or is that a new issue? Is the server local or remote?
SamES 1084 Posted August 22, 2022 Posted August 22, 2022 1 hour ago, SamES said: Have you always had to do that, or is that a new issue? Is the server local or remote?
Waldoo 14 Posted August 23, 2022 Author Posted August 23, 2022 local server hosted on a nas docker image
