seofood 1 Posted January 9, 2023 Posted January 9, 2023 (edited) Same problem here on 2 different Macs. What I found out is if I let the Dev Toolbar (with disable cache) open it runs just fine, so it my be a cache bug. Edited January 9, 2023 by seofood 1
jfpaul@gmail.com 2 Posted January 14, 2023 Posted January 14, 2023 I'm finding that any minor corruption in mkv file causes a movie to stop. I'm using emby on Sony TV. Synology drive running emby server. This happens also on Nvidia shield when playing over WAN. If I go to my windows machine and use VLC I can visually see corrupted artifacts but recovers and plays fine. It's just emby can't seem to recover in this situation.
Gecko 71 Posted January 18, 2023 Posted January 18, 2023 I think that's the third topic opened about that issue Seems like more and more people are experiencing it on safari.
tegeril 0 Posted January 22, 2023 Posted January 22, 2023 This is still happening of course (no server updates since before). Is anyone working on this? Feels like I need to give up on Emby soon.
Luke 42237 Posted June 26, 2023 Posted June 26, 2023 Hi, can you please try Emby for macOS 2.2.9 and let us know how that compares? Thanks.
Luke 42237 Posted July 9, 2023 Posted July 9, 2023 OK, can you try our hosted web app and let us know how it compares: http://app.emby.media Thanks.
rootbeerdan 7 Posted September 27, 2023 Posted September 27, 2023 I am able to replicate this issue consistently on a single song I have which skips in almost the same place every time, and per @seofood's suggestion the issue goes away when I open up the console and disable the cache.
Luke 42237 Posted October 5, 2023 Posted October 5, 2023 On 9/27/2023 at 12:06 PM, rootbeerdan said: I am able to replicate this issue consistently on a single song I have which skips in almost the same place every time, and per @seofood's suggestion the issue goes away when I open up the console and disable the cache. Was there audio transcoding occurring, or direct playing?
rootbeerdan 7 Posted October 8, 2023 Posted October 8, 2023 On 10/5/2023 at 2:09 PM, Luke said: Was there audio transcoding occurring, or direct playing? All direct play, FLAC.
Luke 42237 Posted October 9, 2023 Posted October 9, 2023 On 10/8/2023 at 3:58 AM, rootbeerdan said: All direct play, FLAC. Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
hoonlight 18 Posted April 16, 2024 Posted April 16, 2024 (edited) I initially thought the issue was with my video files. When I play a .mkv file directly, the playback intermittently stops as if the server connection is temporarily lost. This issue occurs only with Safari and the Mac Emby app, while it plays fine on Chrome. I'll check if it's caused by reverse proxy and add the information. Edited April 16, 2024 by hoonlight
hoonlight 18 Posted April 17, 2024 Posted April 17, 2024 (edited) 12 hours ago, hoonlight said: I initially thought the issue was with my video files. When I play a .mkv file directly, the playback intermittently stops as if the server connection is temporarily lost. This issue occurs only with Safari and the Mac Emby app, while it plays fine on Chrome. I'll check if it's caused by reverse proxy and add the information. It was alleviated after changing my nginx settings, but it still happens. Edited April 17, 2024 by hoonlight
hoonlight 18 Posted April 17, 2024 Posted April 17, 2024 Here is my playback log. And here's what I tested for this issue. The nginx settings are the same as in the post below. 1. This issue happens regardless of whether you are connecting directly through the server ip or not. 2. it happens regardless of whether you are playing directly or transcoding. 3. I suspected an issue with HDD power saving, so I used an SSD, but it still happens. 4. I suspected an internet issue, but it happens locally as well, and ping test results are normal even while playback freezes. 5. the same thing happens on my Mac, iPhone, and iPad. 6. It plays fine in chrome with no stuttering at all. when it stops playing, if I wait for a while, it resumes playing again. embyserver (1).txt ffmpeg-remux-1da4284f-d69c-4a37-8934-5777d5511978_1.txt
Solution hoonlight 18 Posted April 18, 2024 Solution Posted April 18, 2024 Update: The issue has been resolved - it was a router issue. Sorry for messing up the post. 1
