Franklin18 0 Posted August 10, 2022 Posted August 10, 2022 Hello, I have a Synology DS920+ running on DSM 7.1-42661 Update 4. When i first installed it, it was all working fine. After a couple of weeks i wasn't able to log-in outside my home network and then it completely stopped working, now i cant access the emby server at all. When i attempt to log in from my Nas server either from my home network or outside i get a white page that says Forbidden
Franklin18 0 Posted August 11, 2022 Author Posted August 11, 2022 How can my setting on my emby account be set to their default setting, since i believe this is where the issue is located
Happy2Play 9812 Posted August 11, 2022 Posted August 11, 2022 (edited) Looks like another recent topic, have you changed any of Emby's Network settings? If so you will need to shutdown Emby and navigate the system.xml and manually edit it. Edited August 11, 2022 by Happy2Play
Franklin18 0 Posted August 11, 2022 Author Posted August 11, 2022 Yes, I made a couple of changes on the Emby dashboard trying to fix an issue I was having, that I wasn’t able to login remotely, only in my home network. After this is when I started getting the forbidden message. Sorry for the ignores but new to all of this, how would I go about shutdown the Emby server and navigation to the system.xml to edit it
Happy2Play 9812 Posted August 11, 2022 Posted August 11, 2022 @Franklin18 Not a Synology user but can't you shut down Emby from DSM Control Panel? As for getting to file you would have to use something like WinSCP to get to the files. 1
FrostByte 5454 Posted August 11, 2022 Posted August 11, 2022 Yes, if you can't get to the Emby server dashboard to shutdown then use Package Center 1
FrostByte 5454 Posted August 11, 2022 Posted August 11, 2022 Use something like WinSCP, putty, Terminal, etc to open and edit /volume1/@appdata/EmbyServer/config/system.xml 1
