MachineLearning 0 Posted August 10, 2022 Posted August 10, 2022 (edited) Hey there, thanks for the continuous effort for making emby the better media app. It used to be fine for 2.0.70g, now for 2.077g whenever I play TrueHD, DTS, sometimes even AAC and flac, the app resorted to software decode instead. I have the 2 checkboxes for passthrough ticked. Most of the time the video won't olay at all, it's just stuck at the very first frame. I dont have external speakers, when it was 2.070g, truehd and dts etc would be software decoded, now either it plays choppy audio, or won't okay at all, no software decoding I'm using 4K Skyworth suc7500 by the way. Funny thing however, the very same app works on my older Skyworth TV, also 4K HDR Edited August 10, 2022 by MachineLearning Add info
Luke 42245 Posted August 10, 2022 Posted August 10, 2022 @MachineLearning  Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!  1
ebr 16337 Posted August 10, 2022 Posted August 10, 2022 12 hours ago, MachineLearning said: I dont have external speakers, Hi. In that case, you want to uncheck these options: 12 hours ago, MachineLearning said: I have the 2 checkboxes for passthrough ticked Please let us know if that solves your issue. 1
MachineLearning 0 Posted August 12, 2022 Author Posted August 12, 2022 (edited) Hey there, DTS MA, Dolby TrueHD, flac are fine now, AAC is still not working. The video would play like 1 second then stops right there. Thanks for pointing me out. DTS MA and ad Dolby TrueHD triggered software decode whereas flac was direct playing as per stat for nerds Edited August 12, 2022 by MachineLearning
ebr 16337 Posted August 12, 2022 Posted August 12, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Â
MachineLearning 0 Posted August 12, 2022 Author Posted August 12, 2022 I did, so far so good, although the controls can be awkward at times in the meantime, I'll try out the latest TV apk
MachineLearning 0 Posted August 12, 2022 Author Posted August 12, 2022 same case for 2.079g, aac won't play. I had to downgrade to 2.074g
Luke 42245 Posted August 17, 2022 Posted August 17, 2022 On 8/12/2022 at 12:55 PM, MachineLearning said: I did, so far so good, although the controls can be awkward at times in the meantime, I'll try out the latest TV apk Hi, what do you mean by the controls can be awkward?
MachineLearning 0 Posted August 20, 2022 Author Posted August 20, 2022 Emby for android mobile's TV mode is not optimized for TV remote
MachineLearning 0 Posted August 20, 2022 Author Posted August 20, 2022 For example, when I long press OK on emby for android TV apk while playing video, the stats for nerds will pop up, said shortcut is not available for Emby Android mobile version, I had to toggle manually for stats for nerds to show
Luke 42245 Posted August 20, 2022 Posted August 20, 2022 9 hours ago, MachineLearning said: For example, when I long press OK on emby for android TV apk while playing video, the stats for nerds will pop up, said shortcut is not available for Emby Android mobile version, I had to toggle manually for stats for nerds to show Is that the only thing? What else?
knitowskimedia 9 Posted August 25, 2022 Posted August 25, 2022 On 8/20/2022 at 1:48 PM, Luke said: Is that the only thing? What else? I'm not the original poster but when you change a setting (like which audio track you want to play) the whole screen greys out.
Luke 42245 Posted August 25, 2022 Posted August 25, 2022 2 hours ago, knitowskimedia said: I'm not the original poster but when you change a setting (like which audio track you want to play) the whole screen greys out. When does it gray out? Before or after changing the setting?
knitowskimedia 9 Posted August 25, 2022 Posted August 25, 2022 11 minutes ago, Luke said: When does it gray out? Before or after changing the setting? When you click the box to change the setting. The whole screen goes grey, with only the options in the middle. When you select an option it goes back to the show/movie info screen. I've also noticed that the standard Android app when used on Android TV will sometimes start playing the audio while remaining on the show/movie info screen. This will usually change to show the video as well after a couple seconds (in sync with the audio), but it sometime will just stay on the info screen. The device I'm using is the Chromecast with Google TV.
Luke 42245 Posted August 25, 2022 Posted August 25, 2022 35 minutes ago, knitowskimedia said: When you click the box to change the setting. The whole screen goes grey, with only the options in the middle. When you select an option it goes back to the show/movie info screen. I've also noticed that the standard Android app when used on Android TV will sometimes start playing the audio while remaining on the show/movie info screen. This will usually change to show the video as well after a couple seconds (in sync with the audio), but it sometime will just stay on the info screen. The device I'm using is the Chromecast with Google TV. Is this during video playback, or before?
knitowskimedia 9 Posted August 26, 2022 Posted August 26, 2022 22 hours ago, Luke said: Is this during video playback, or before? before
