Luke 42186 Posted August 9, 2022 Posted August 9, 2022 Hi, are you still seeing this now? I am able to reach fanart. You could have something blocking your connection, or fanart could have just been having temporary issues on their end.
Waldoo 14 Posted August 9, 2022 Author Posted August 9, 2022 (edited) I can Access the site just the images are not showing in emby. my Nas install emby fanart is fine. its just windows install not working Edited August 9, 2022 by Waldoo
Happy2Play 9800 Posted August 9, 2022 Posted August 9, 2022 27 minutes ago, Waldoo said: I can Access the site just the images are not showing in emby. my Nas install emby fanart is fine. its just windows install not working But their website would still be different then the link in your log as it is an api server. I am currently not seeing any issues and clicking the timed out links in your log opens. So either it resolved itself or all the things Luke mentioned above.
Waldoo 14 Posted August 9, 2022 Author Posted August 9, 2022 What do I have to do to make sure I’m not blocking the connection?
Luke 42186 Posted August 9, 2022 Posted August 9, 2022 4 hours ago, Waldoo said: What do I have to do to make sure I’m not blocking the connection? The answer to that is specific to your own environment. Are you using a VPN?
Waldoo 14 Posted August 11, 2022 Author Posted August 11, 2022 Should I reinstall the os ? says something is blocking the socket
Solution Waldoo 14 Posted August 11, 2022 Author Solution Posted August 11, 2022 (edited) Found the problem, one of several ports emby uses using the same port I set in qbit by chance. I used netstat -a -o -n -b in command prompt as admin to see the ports Edited August 11, 2022 by Waldoo
