pünktchen 1410 Posted November 3, 2022 Posted November 3, 2022 Just now, softworkz said: That's not a good baseline, as it's about processing 30-50 GB files. Then an external ssd maybe
softworkz 5133 Posted November 3, 2022 Posted November 3, 2022 7 minutes ago, softworkz said: at least not on an unraid volume. Maybe a folder on the host system disk. If that's not possible, then take a screwdriver, open the case and add a new (or used) SATA drive to the system (but standalone - I mean to the chipset's SATA connectors, not as a RAID drive, not like you would probably add a drive normally). If that doesn't get you to a working setup, you'll need to consider installing Emby on the host OS - that's the last resort in trying. The Emby packages are not invasive and not destructive, they don't mess with your system files, so I wouldn't be that much afraid of - but it's your decision. Bottom line is: So far you were focusing on showing everybody what's not working and how it wasn't working Your new homework is to get it working on your system by doing everything differently from what you've done before (because we already know that it's not an Emby problem)
softworkz 5133 Posted November 3, 2022 Posted November 3, 2022 4 minutes ago, softworkz said: doing everything differently from what you've done before Also use different files from a totally different source (e.g. www.demolandia.net).
b0mb 36 Posted November 3, 2022 Author Posted November 3, 2022 i´ve just tried a fresh instance with a new share and a 2nd container and told emby to store the metadata in the moviedolder... that was working well for all data except the thumbs ^^
softworkz 5133 Posted November 3, 2022 Posted November 3, 2022 21 minutes ago, b0mb said: with a new share I wish you good luck in finding the cause. It's not an Emby issue, but I gave you pointers and a strategy to pinpoint. What you make out of that is up to you. softworkz
WirbelFCM 0 Posted August 9, 2025 Posted August 9, 2025 On 8/9/2022 at 10:10 AM, b0mb said: Gibt es eine Möglichkeit, die bereits erstellten Thumbnails zu löschen und den Prozess noch mal neu zu starten, oder kann ich diesen vielleicht sogar nur für die betreffenden Filme forcieren? Gibt es inzwischen eine Lösung für dieses Problem? Wie stößt man diesen Vorgang nochmal neu an, wenn der erste Versuch mißlang? Ich finde irgendwie keine Option dafür
Luke 42239 Posted August 10, 2025 Posted August 10, 2025 On 8/9/2025 at 9:53 AM, WirbelFCM said: Gibt es inzwischen eine Lösung für dieses Problem? Wie stößt man diesen Vorgang nochmal neu an, wenn der erste Versuch mißlang? Ich finde irgendwie keine Option dafür Hi there, can you please describe your issue in more detail?
Killface69 96 Posted August 16, 2025 Posted August 16, 2025 On 09/08/2025 at 15:53, WirbelFCM said: Gibt es inzwischen eine Lösung für dieses Problem? Wie stößt man diesen Vorgang nochmal neu an, wenn der erste Versuch mißlang? Ich finde irgendwie keine Option dafür Schau mal bei Emby Server -> Geplante Aufgaben. Dort finndest du auf der Hälfte der Seite "Video preview thumbnail extraction"; du kannst die Aufgabe mit dem Play Button direkt neu starten oder die die Aufgabenplanung per Klick darauf anzeigen lassen/ändern. 1
