b0mb 36 Posted September 10, 2022 Author Posted September 10, 2022 just tried the Emby Docker Container from linuxserver.io Team and the Problem is here also present.... hmmmm....
b0mb 36 Posted September 29, 2022 Author Posted September 29, 2022 (edited) just tried latest Emby Beta Build and the problem is still present.... really annoying ^^ Edited September 29, 2022 by b0mb
Luke 42239 Posted September 29, 2022 Posted September 29, 2022 8 hours ago, b0mb said: just tried latest Emby Beta Build and the problem is still present.... really annoying ^^ Can you please provide new log file examples? Thanks.
b0mb 36 Posted September 29, 2022 Author Posted September 29, 2022 embyserver-63800080766.txt embyserver (1).txt
b0mb 36 Posted September 30, 2022 Author Posted September 30, 2022 2 hours ago, softworkz said: The extraction logs please. extract-multi-image-99020BEB4F59_1.txt sorry - one file was wrong
softworkz 5133 Posted October 4, 2022 Posted October 4, 2022 This should be fixed now for the next beta. Let's try again once it's out. 1
b0mb 36 Posted October 13, 2022 Author Posted October 13, 2022 On 10/4/2022 at 3:15 AM, softworkz said: This should be fixed now for the next beta. Let's try again once it's out. just tried - problem is still present ^^
Luke 42239 Posted October 13, 2022 Posted October 13, 2022 21 minutes ago, b0mb said: just tried - problem is still present ^^ What exactly did you try to do? What exactly happened?
b0mb 36 Posted October 13, 2022 Author Posted October 13, 2022 (edited) 9 minutes ago, Luke said: What exactly did you try to do? What exactly happened? The Same like every time.... added a movie and after everything was identified only 10 of 24 chapter images were extracted. Edited October 13, 2022 by b0mb
Luke 42239 Posted October 13, 2022 Posted October 13, 2022 12 minutes ago, b0mb said: The Same like every time.... added a movie and after everything was identified only 10 of 24 chapter images were extracted. Can you please attach the emby server log? Thanks.
b0mb 36 Posted October 13, 2022 Author Posted October 13, 2022 1 hour ago, Luke said: Can you please attach the emby server log? Thanks. nevermind I´ve deleted and re-added the content and now all chapter images have been extructed So i´ve just restarted the extraction for my whole collection and tell you tomorrow about the result 2
b0mb 36 Posted October 14, 2022 Author Posted October 14, 2022 (edited) please find attached the new logfiles ... however when i tried yesterday it only worked for one single movie.... extract-multi-image-4AE583710129_1.txt embyserver.txt edit: it seems like the problem appears randomly... last time i´ve added a movie and got 11 of 12 thumbs extracted where today for the same movie emby only extracts 3 of 12 thumbs Edited October 14, 2022 by b0mb
softworkz 5133 Posted October 14, 2022 Posted October 14, 2022 /mnt/4K/!4K/ Where are your files stored, what kind of storage is this?
b0mb 36 Posted October 14, 2022 Author Posted October 14, 2022 57 minutes ago, softworkz said: /mnt/4K/!4K/ Where are your files stored, what kind of storage is this? /mnt is where all my folders for the shares of my unRAID server are located /mnt ist completetly passed through to the docker container
softworkz 5133 Posted October 14, 2022 Posted October 14, 2022 19 minutes ago, b0mb said: /mnt is where all my folders for the shares of my unRAID server are located /mnt ist completetly passed through to the docker container But is /mnt/4K a local disk or a mounted network location? I wonder whether there's some problem with seeking, because the extraction makes intensive use of seeking and it is running incredibly slow, though.
b0mb 36 Posted October 14, 2022 Author Posted October 14, 2022 6 minutes ago, softworkz said: But is /mnt/4K a local disk or a mounted network location? I wonder whether there's some problem with seeking, because the extraction makes intensive use of seeking and it is running incredibly slow, though. yeah! It´s really slow.... that´s true mnt/ is the container path, on the host this path is /mnt/User i can´t describe how the folder structure on unRAID is working since it´s working similar to snapRAID
b0mb 36 Posted October 19, 2022 Author Posted October 19, 2022 10 minutes ago, Luke said: Has it completed? nopes
b0mb 36 Posted October 24, 2022 Author Posted October 24, 2022 4 minutes ago, Luke said: Have you updated to the latest build? yep
Luke 42239 Posted October 24, 2022 Posted October 24, 2022 10 minutes ago, b0mb said: yep How does that compare?
b0mb 36 Posted October 24, 2022 Author Posted October 24, 2022 1 minute ago, Luke said: How does that compare? it´s still the same... everything that´s not 4k is extracting fine and for 4k stuff you need some luck.... sometimes emby is extracting only 3 thumbnails and sometimes all
Luke 42239 Posted October 24, 2022 Posted October 24, 2022 4 minutes ago, b0mb said: it´s still the same... everything that´s not 4k is extracting fine and for 4k stuff you need some luck.... sometimes emby is extracting only 3 thumbnails and sometimes all Can you please provide a new log example? Thanks.
