b0mb 36 Posted August 9, 2022 Posted August 9, 2022 Hallo zusammen, mir ist aufgefallen, dass Emby bei einigen meiner Filme nur die Hälfte der Thumbnails extrahiert. Gibt es eine Möglichkeit, die bereits erstellten Thumbnails zu löschen und den Prozess noch mal neu zu starten, oder kann ich diesen vielleicht sogar nur für die betreffenden Filme forcieren? Thx! b0mb
Luke 42239 Posted August 10, 2022 Posted August 10, 2022 Hi there, can you please provide an example? Thanks.
b0mb 36 Posted August 10, 2022 Author Posted August 10, 2022 What do you exactly mean with XMPL in this case?
Luke 42239 Posted August 10, 2022 Posted August 10, 2022 14 hours ago, b0mb said: What do you exactly mean with XMPL in this case? Hi, where are you seeing xmpl?
Happy2Play 9811 Posted August 11, 2022 Posted August 11, 2022 10 minutes ago, Eddie6411284 said: I tap on: example = xmpl On 8/9/2022 at 1:10 AM, b0mb said: I've noticed that Emby only extracts half of the thumbnails on some of my films. Dev needs you to provide a specific example this happens on. Dev benötigt von Ihnen ein konkretes Beispiel, an dem dies geschieht.
b0mb 36 Posted August 11, 2022 Author Posted August 11, 2022 Groundhog Day 4k only Thumbnails for Chapter 1 to 10 are extracted Mama Mia! Here we go again! 4k only 1 to 6 Menace II Society 4K only 1 to 6
Luke 42239 Posted August 11, 2022 Posted August 11, 2022 11 hours ago, b0mb said: Groundhog Day 4k only Thumbnails for Chapter 1 to 10 are extracted Mama Mia! Here we go again! 4k only 1 to 6 Menace II Society 4K only 1 to 6 Please attach the emby server log from when this happened: Thanks.
b0mb 36 Posted August 11, 2022 Author Posted August 11, 2022 please find attached 2 .log Files extract-multi-image-dd925d98-f1e1-495a-8c59-bdf239b0178f_1.txt embyserver.txt
softworkz 5133 Posted September 3, 2022 Posted September 3, 2022 Would you be able to try the latest beta? I think it should be fixed already. If not, we'd need to try to reproduce with your file. Thanks, sw
b0mb 36 Posted September 6, 2022 Author Posted September 6, 2022 just testing which is going to take some hours but the problem seems to be successfully fixed :THUMBS UP:
softworkz 5133 Posted September 7, 2022 Posted September 7, 2022 Ok, great. Thanks a lot for the feedback!
b0mb 36 Posted September 8, 2022 Author Posted September 8, 2022 hmmm.... i´ve just seen that the problem is still present but as far as i can see it only seems to be present when the movies are 4K HEVC encoded....
softworkz 5133 Posted September 8, 2022 Posted September 8, 2022 Did you try with the latest beta 4.8.0.8? Could you please provide the ffmpeg log from extraction?
b0mb 36 Posted September 8, 2022 Author Posted September 8, 2022 attached 3 of them extract-multi-image-230d55db-39e1-4487-ae82-630d52ed74af_1.txt extract-multi-image-406402dc-dc29-44d1-a2a7-c6c089992d5a_1.txt extract-multi-image-18dd547b-41aa-470c-a534-924e88477f42_1.txt
softworkz 5133 Posted September 8, 2022 Posted September 8, 2022 OK, thanks. Looks like some crash is happening due to those logs appearing to end prematurely. Would you be able to provide a file for testing in some way? (privately, please contact me via PM) Thanks, sw
b0mb 36 Posted September 9, 2022 Author Posted September 9, 2022 providing a file of such a big size is actually not possible for me i think but it shouldn´t be a big problem for you to reproduce the error because this happens to 95% of my 4k movies.... and as it seems it only happens to 4k ^^
softworkz 5133 Posted September 9, 2022 Posted September 9, 2022 I can't reproduce: extract-multi-image-582fe720-7c64-47a6-9399-e9383b6567f6_1.txt
b0mb 36 Posted September 9, 2022 Author Posted September 9, 2022 just for trying some things is it possible to build new thumbs for single movies or delete old thumbs to try rebuilding those?
softworkz 5133 Posted September 9, 2022 Posted September 9, 2022 (edited) It's easiest to enable Save video preview thumbnails into media folders and Save artwork into media folders (when you have chosen to extract chapter images - like in your case) so you can see the results in the media folder and delete them. You can also make a small change to the file name.. Edited September 9, 2022 by softworkz
b0mb 36 Posted September 9, 2022 Author Posted September 9, 2022 (edited) is there any other solution? i´ve sourced out all my media data to the cache SSD of my unraid server to prevent disks spinning up edit: I´ve just added a 10GIG file where the problem is present and going to put it on some webspace now Edited September 9, 2022 by b0mb 1
softworkz 5133 Posted September 9, 2022 Posted September 9, 2022 Thanks a lot for the test file. The extraction went fine here: extract-multi-image-eeabc0bc-24b9-4a2d-ace9-1cf7238741f3_1.txt So it could be either due to some updates I have in the local version or some Linux vs. Windows issue. Let's wait for 4.8.0.9 and try again then.
b0mb 36 Posted September 9, 2022 Author Posted September 9, 2022 thx for testing! let´s wait for future updates!
