arrbee99 1836 Posted September 2, 2022 Author Posted September 2, 2022 Hokey dokey, thanks very much for the time and the effort.
TMCsw 259 Posted September 2, 2022 Posted September 2, 2022 Try this, I missed something @echo off :: Set file specification set FileSpec="m:\Films\*.mkv" :: Set location of MediaInfo CLI executable (directory where mediainfo.exe CLI version is located) set MICLI="C:\bin\mediainfo" SETLOCAL SETLOCAL ENABLEEXTENSIONS SETLOCAL ENABLEDELAYEDEXPANSION if not exist "%MICLI:"=%\mediainfo.exe" goto :PNF if not exist "%FileSpec:"=%" goto :FNF FOR /F "delims=" %%m in ('dir /a-s /b /s "%FileSpec:"=%"') do ( "%MICLI%\mediainfo" --Inform="Video;%%Duration/String3%%" "%%m" > %TEMP%\Duration.tmp call :runff "%%m" echo ==================================================== ) goto :cleanup :runff set /p Duration= < %TEMP%\Duration.tmp echo ffmpeg -y -hide_banner -v info -i %1 -to %Duration% -map 0:a? -map 0:s? -map 0:v -c copy "%~dpn1_length.mkv" goto :eof :cleanup if exist %TEMP%\Duration.tmp DEL %TEMP%\Duration.tmp Pause exit /b :FNF echo file not found %FileSpec% pause exit /b :PNF echo mediainfo.exe not found in directory %MICLI% pause
arrbee99 1836 Posted September 2, 2022 Author Posted September 2, 2022 (edited) looks promising (displays this) - ffmpeg -y -hide_banner -v info -i "Y:\Ripping\Post Handbrake\Hawaii Five-0 Season 1\Hawaii Five-0 Season 1 Disc 1\S01E01 Pilot.mkv" -to 00:44:38.676 -map 0:a? -map 0:s? -map 0:v -c copy "Y:\Ripping\Post Handbrake\Hawaii Five-0 Season 1\Hawaii Five-0 Season 1 Disc 1\S01E01 Pilot_length.mkv" ==================================================== ffmpeg -y -hide_banner -v info -i "Y:\Ripping\Post Handbrake\Hawaii Five-0 Season 1\Hawaii Five-0 Season 1 Disc 1\S01E02 'Ohana (Family).mkv" -to 00:42:33.551 -map 0:a? -map 0:s? -map 0:v -c copy "Y:\Ripping\Post Handbrake\Hawaii Five-0 Season 1\Hawaii Five-0 Season 1 Disc 1\S01E02 'Ohana (Family)_length.mkv" ==================================================== ffmpeg -y -hide_banner -v info -i "Y:\Ripping\Post Handbrake\Hawaii Five-0 Season 1\Hawaii Five-0 Season 1 Disc 1\S01E03 Malama Ka Aina (Respect the Land).mkv" -to 00:40:58.456 -map 0:a? -map 0:s? -map 0:v -c copy "Y:\Ripping\Post Handbrake\Hawaii Five-0 Season 1\Hawaii Five-0 Season 1 Disc 1\S01E03 Malama Ka Aina (Respect the Land)_length.mkv" ==================================================== Press any key to continue . . . then it exits. Is this as desired ? Edited September 2, 2022 by arrbee99
TMCsw 259 Posted September 2, 2022 Posted September 2, 2022 Yes, you are now up to step 6: if the time(s) indicated after the -to are correct remove the “echo” before “ffmpeg...” then run it again.
arrbee99 1836 Posted September 2, 2022 Author Posted September 2, 2022 That seems to work rather excellently, thank you. One thing (so far...) it does just copy the video, audio and subtitles (everything) to the new file ?
TMCsw 259 Posted September 2, 2022 Posted September 2, 2022 The -map parameters control what gets copied your settings will only copy the main stream Video/Audio/Subtitles. If you want everything then simply remove the "-map 0:a? -map 0:s? -map 0:v" from the ffmpeg line.
arrbee99 1836 Posted September 3, 2022 Author Posted September 3, 2022 Hokey dokey. Thanks very much for that.
arrbee99 1836 Posted September 3, 2022 Author Posted September 3, 2022 Seems a bit the other way round to me, for instance for the first episode with 4 audio tracks and leaving the map bits in, the output had 4 audio tracks, but remove the map bit and it only had one track.
