sirbubber 0 Posted August 7, 2022 Posted August 7, 2022 I have been using EMBY as media server for a long time. it runs on a Qnap ts-453be 8GB ram I use it for my DVD and Blue rays, which I watch on Apple devices Lately I started buying 4K Blue rays, and ripping them with makeMKV. But here is where the problem starts. So I have premium Subs and run playback from EMBY client apps or MRMC (KODI for Apple). 99.8% of content in 4K starts buffering or stop playback after some sec. in any EMBY player. AppleTV, Ipad or Iphone. I have tried with or without transcoding, By setting the user up to no transcoding. I have also setting EMBY server into MRMC, and here playback has no problem. All 4K ripped movies playback fine. Why does MRMC playback fine, but the EMBY client stutters and buffers? EMBY vs MRMC(KODI).pdf
Luke 42239 Posted August 7, 2022 Posted August 7, 2022 @sirbubber Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
sirbubber 0 Posted August 8, 2022 Author Posted August 8, 2022 Thank you for your understanding, I'm new here. So I tried with more information and added the log file. All playback was done on AppleTV 4K - the EMBY server is still running on Qnap ts-453be 8GB ram. First I played Batman in the EMBY app, and here I get stutters right a way, and freezes multiple times I stop playback on EMBY Then I start the same movie, Batman in MRMC (Kodi for Apple) on stuttering or freezes. Again stop the playback Then I also try Ant-man and the Wasp, same results Emby player stutters, but no freezes, but on MRMC no stutter For Batman on EMPY, playback was started at timecode: 2022-08-08 15:41:03.822 And ended: 2022-08-08 15:42:06.947 For Batman on MRMC was started at this timecode: 2022-08-08 15:43:12.418 And ended: 2022-08-08 15:43:58.320 For Ant-man & the Wasp on EMPY, playback was started at timecode: 2022-08-08 15:45:15.288 And ended: 2022-08-08 15:45:36.662 For Ant-man & the wasp on MRMC was started at this timecode: 2022-08-08 15:45:49.558 And ended: 2022-08-08 15:46:15.225 embyserver (1).txt
Luke 42239 Posted August 17, 2022 Posted August 17, 2022 On 8/12/2022 at 1:29 PM, sirbubber said: do you see anything in my logs? hi @sirbubber can you please provide a log example from playing with an Emby app, such as Ipad or our Apple TV app? Thanks !
sirbubber 0 Posted August 17, 2022 Author Posted August 17, 2022 Hi this is included in the log file. please see at this time codes: Played Ant-man & the Wasp on EMPY, on Apple TV playback was started at timecode: 2022-08-08 15:45:15.288 And ended: 2022-08-08 15:45:36.662
vdatanet 1619 Posted August 17, 2022 Posted August 17, 2022 Emby Server + HEVC HDR + Emby Player (ipadOS, tvOS, iOS) = bad experience (since many years)
Luke 42239 Posted August 17, 2022 Posted August 17, 2022 4 minutes ago, sirbubber said: Hi this is included in the log file. please see at this time codes: Played Ant-man & the Wasp on EMPY, on Apple TV playback was started at timecode: 2022-08-08 15:45:15.288 And ended: 2022-08-08 15:45:36.662 Hi there, did you forget to attach the log file?
Luke 42239 Posted August 17, 2022 Posted August 17, 2022 4 minutes ago, vdatanet said: Emby Server + HEVC HDR + Emby Player (ipadOS, tvOS, iOS) = bad experience (since many years) Relief is coming soon because the iOS app is about to get an automatic switch to the native player whenever possible. And then after that will be ported into the Apple TV app. 1
