nijhof 0 Posted August 6, 2022 Posted August 6, 2022 I’m using NextPVR 5.2.7.220410 with Emby Server 4.7.6.0 and the NextPVR Plugin 4.0.1.0 from the catalogue. Everything is working fine, except for the recording function. I’d like to use the recording function of NextPVR but currently Emby is using its internal recording function. Am I missing something?
Solution emveepee 133 Posted August 6, 2022 Solution Posted August 6, 2022 No you have it, that is the direction Emby wanted to take the interface. Martin 1
muehlberger 4 Posted October 26, 2022 Posted October 26, 2022 Another ongoing question: i program recordings via the NextPVR app on iOS. Works fine. BUT the recordings dont show up in Emby. Is there any config option to achieve that? greetings, A
emveepee 133 Posted October 26, 2022 Posted October 26, 2022 Unfortunately Emby removed this functionality so recordings on the two program are independent. You would need to use an Emby app on iOS. Alternatively import NextPVR recordings through the video library. Martin
