Lyfesaver 135 Posted October 9, 2024 Posted October 9, 2024 The other version is Emby for Android 3.4.16 and also does not have the ability to hide the episodes
Lyfesaver 135 Posted October 9, 2024 Posted October 9, 2024 I feel like my issue ended up going off topic. Should I start a new thread?
ebr 16354 Posted October 9, 2024 Posted October 9, 2024 1 hour ago, Lyfesaver said: The other version is Emby for Android 3.4.16 and also does not have the ability to hide the episodes That app doesn't even have the option to show them at all. What version of the server are you on?
Lyfesaver 135 Posted October 9, 2024 Posted October 9, 2024 8 minutes ago, ebr said: That app doesn't even have the option to show them at all. What version of the server are you on? You are right the Android version does not show the missing eps
ebr 16354 Posted October 9, 2024 Posted October 9, 2024 Just now, Lyfesaver said: You are right the Android version does not show the missing eps Okay, then you are good to go then?
Lyfesaver 135 Posted October 9, 2024 Posted October 9, 2024 2 hours ago, ebr said: Okay, then you are good to go then? No. The missing items are shown. I was told in v 2.1.11+ that an option to not show them would be there. I am now not 2.1.14a and that option is not listed in the settings.
Lyfesaver 135 Posted October 9, 2024 Posted October 9, 2024 I dont want to have to use the Android version on my FireTV. While it offers me full control (and I like that) the interface differences are enough to make it unfriendly to remote control users
Lyfesaver 135 Posted October 9, 2024 Posted October 9, 2024 2 hours ago, ebr said: Okay, then you are good to go then? This is what I need to find: I still dont understand how I could have turned that on using v 2.1.06a when it was not out until 2.1.11. This is one of those three questions I asked earlier. Nothing is adding up here y'all.
ebr 16354 Posted October 10, 2024 Posted October 10, 2024 Not sure why you are not seeing the option but try the latest beta Amazon version. beta release of the app 1
Lyfesaver 135 Posted October 10, 2024 Posted October 10, 2024 2 hours ago, ebr said: Not sure why you are not seeing the option but try the latest beta Amazon version. beta release of the app I don't know how to do that. I did check and 3 FireTV cubes (all different generations, 1st thru 3rd) and 2 FireTV sticks (both the most current gen) and all of them are on 2.1.06a (aside from the one that updated to 2.1.14 after I deleted it and reinstalled). I don't mean to be melodramatic but I do want to exaggerate so I am not misunderstood. Feel free to school me or put me in place but I feel like we are talking about the color of band-aids to use when the problem at hand is that I have a bullet hole in my head. Why I am not seeing the option is problem #3. Problem #1 is why am I seeing them on version 2.1.06a when you cant even turn the missing eps on at all. Problem #2a is why cant I upgrade ANY of my Emby apps. I have verified that all my other apps (I only use 4 others) are up to date and have updated on time. This issue is ONLY with the Emby for Fire TV app. I suppose my Emby for Android is current. Problem #2b is if I have to manually update this thing (which I used to not have to do) how will I know if there is an update in the future? Do I have to follow that thread to stay up-to-date? Problem #3 is why the option to turn them off is not listed. Problem #4 when auto playing next episodes and it is missing I have manually click next for each episode (this might be fixed once I can turn them off) I feel like there are multiple issues here to just one big issue that is being exposed in many ways and I dont know how to tackle these. Once I look for info on how to manually update and do it I do not think, at all, that it will address everything listed above. Also, because I was not a good dude and did not say so earlier, I need to say so now... thank you ebr, and everyone else, for trying to help. I know I am not the easiest person to deal with when I get frustrated like I am
ebr 16354 Posted October 10, 2024 Posted October 10, 2024 20 minutes ago, Lyfesaver said: Problem #1 is why am I seeing them on version 2.1.06a when you cant even turn the missing eps on at all. Because server changed its behavior. 21 minutes ago, Lyfesaver said: Problem #2a is why cant I upgrade ANY of my Emby apps Because you must've previously side-loaded them like I suggested you do with the current beta. 21 minutes ago, Lyfesaver said: Problem #3 is why the option to turn them off is not listed See problem 1 22 minutes ago, Lyfesaver said: Problem #4 when auto playing next episodes and it is missing I have manually click next for each episode (this might be fixed once I can turn them off) Correct. I would suggest re-installing the app from the Amazon store or side loading from the APK I linked. 1
